TextAttachmentType 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 615| 评论: 0|原作者: admin|来自: AutoCAD
指定领导者如何与文本连接。
object.TextAttachmentType
类型:MLeader
此属性应用于的对象。
只读:不
类型:枚举AcTextAttachmentType
  • acAttachmentAllLine
  • acAttachmentBottomLine
  • acAttachmentBottomOfBottom
  • acAttachmentBottomOfTop
  • acAttachmentBottomOfTopLine
  • acAttachmentMiddle
  • acAttachmentMiddleOfBottom
  • acAttachmentMiddleOfTop
  • acAttachmentTopOfTop
Not available
Not available
GMT+8, 2026-11-13 14:02
