TempXRefPath 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 566| 评论: 0|原作者: admin|来自: AutoCAD
指定外部引用文件的位置。
object.TempXRefPath
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
用于搜索外部引用文件的目录的驱动器和路径。
如果在属性上选择需求加载,则此位置将用于外部参照的副本。acEnableWithCopyXRefDemandLoad
Sub Example_TempXRefPath()
    ' TempXRefPath. It then changes the value, and finally
    Dim currTempXRefPath As String
    Dim newTempXRefPath As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current TempXRefPath value
    currTempXRefPath = preferences.Files.TempXrefPath
    MsgBox "The current value for TempXRefPath is " & currTempXRefPath, vbInformation, "TempXRefPath Example"
    ' Change the value for TempXRefPath
    newTempXRefPath = "TestTempXRefPath"
    preferences.Files.TempXrefPath = newTempXRefPath
    MsgBox "The new value for TempXRefPath is " & newTempXRefPath, vbInformation, "TempXRefPath Example"
    ' Reset TempXRefPath to its original value
    preferences.Files.TempXrefPath = currTempXRefPath
    MsgBox "The TempXRefPath value is reset to " & currTempXRefPath, vbInformation, "TempXRefPath Example"
(defun c:Example_TempXRefPath()
    ;; TempXRefPath. It then changes the value, and finally
    ;; Retrieve the current TempXRefPath value
    (setq currTempXRefPath (vla-get-TempXrefPath (vla-get-Files preferences)))
    (alert (strcat "The current value for TempXRefPath is " currTempXRefPath))
    ;; Change the value for TempXRefPath
    (setq newTempXRefPath "TestTempXRefPath")
    (vla-put-TempXrefPath (vla-get-Files preferences) newTempXRefPath)
    (alert (strcat "The new value for TempXRefPath is " newTempXRefPath))
    ;; Reset TempXRefPath to its original value
    (vla-put-TempXrefPath (vla-get-Files preferences) currTempXRefPath)
    (alert (strcat "The TempXRefPath value is reset to " currTempXRefPath))
GMT+8, 2026-11-13 13:55
