TempFileExtension 属性 (ActiveX)
指定临时文件的扩展名。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 此字符串必须介于 1 到 3 个字符之间(含 1 到 3 个字符)。 言论此属性的默认值为 ac$。 临时文件扩展名是用于临时文件的一到三个字符的扩展名。在多用户环境中,可以通过为每个用户指定不同的名称来避免混淆。 例子VBA: Sub Example_TempFileExtension()
' TempFileExtension. It then changes the value, and finally
Dim currTempFileExtension As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current TempFileExtension value
currTempFileExtension = preferences.OpenSave.TempFileExtension
MsgBox "The current value for TempFileExtension is " & preferences.OpenSave.TempFileExtension, vbInformation, "TempFileExtension Example"
' Change the value for TempFileExtension
preferences.OpenSave.TempFileExtension = "@@@"
MsgBox "The new value for TempFileExtension is " & preferences.OpenSave.TempFileExtension, vbInformation, "TempFileExtension Example"
' Reset TempFileExtension to its original value
preferences.OpenSave.TempFileExtension = currTempFileExtension
MsgBox "The TempFileExtension value is reset to " & preferences.OpenSave.TempFileExtension, vbInformation, "TempFileExtension Example"
可视化 LISP: (vl-load-com)
(defun c:Example_TempFileExtension()
;; TempFileExtension. It then changes the value, and finally
;; Retrieve the current TempFileExtension value
(setq currTempFileExtension (vla-get-TempFileExtension (vla-get-OpenSave preferences)))
(alert (strcat "The current value for TempFileExtension is " currTempFileExtension))
;; Change the value for TempFileExtension
(vla-put-TempFileExtension (vla-get-OpenSave preferences) "@@@")
(alert (strcat "The new value for TempFileExtension is " (vla-get-TempFileExtension (vla-get-OpenSave preferences))))
;; Reset TempFileExtension to its original value
(vla-put-TempFileExtension (vla-get-OpenSave preferences) currTempFileExtension)
(alert (strcat "The TempFileExtension value is reset to " (vla-get-TempFileExtension (vla-get-OpenSave preferences))))
GMT+8, 2026-11-14 14:21
