SuppressZeroFeet 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 912| 评论: 0|原作者: admin|来自: AutoCAD
指定在尺寸值中隐含零英尺测量值。
object.SuppressZeroFeet
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:禁止显示零英尺测量值。
  • False:不要禁止显示零英尺测量值。
此属性的初始值为 。False
注意:此属性将覆盖给定维度的 DIMZIN 系统变量的值。
Sub Example_SuppressZeroFeet()
   ' uses SuppressZeroFeet to suppress or view the display of
   ' zero feet in the alternate dimension display
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point1(0) = 0: point1(1) = 5: point1(2) = 0
    point2(0) = 5: point2(1) = 5: point2(2) = 0
    ' Set the dimension display to a style that works with SuppressZeroFeet
    dimObj.UnitsFormat = acDimLArchitectural
Toggle:
    Select Case MsgBox("Press OK to suppress or view the display of zero feet in the dimension", vbOKCancel)
        Case vbOK
            ' Toggle the display of zero feet for the dimension value
            dimObj.SuppressZeroFeet = Not (dimObj.SuppressZeroFeet)
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
(defun c:Example_SuppressZeroFeet()
    ;; uses SuppressZeroFeet to suppress or view the display of
    ;; zero feet in the alternate dimension display
    ;; Define the dimension
    (setq point1 (vlax-3d-point 0 5 0)
          point2 (vlax-3d-point 5 5 0)
    (vla-ZoomAll acadObj)
    ;; Set the dimension display to a style that works with SuppressZeroFeet
    (vla-put-UnitsFormat dimObj acDimLArchitectural)
    ;; Toggle the display of zero feet for the dimension value
    (vla-put-SuppressZeroFeet dimObj (if (= (vla-get-SuppressZeroFeet dimObj) :vlax-true) :vlax-false :vlax-true))
    (alert "Suppression of zero feet toggled.")
    ;; Toggle the display of zero feet for the dimension value back to previous state
    (alert "Suppression of zero feet toggled back.")
GMT+8, 2026-11-12 12:22
