SuppressTrailingZeros 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 726| 评论: 0|原作者: admin|来自: AutoCAD
指定禁止显示维度值中的尾随零。
object.SuppressTrailingZeros
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:禁止在十进制尺寸中显示尾随零。例如,12.5000 变为 12.5。
  • False: 不要禁止十进制尺寸中的尾随零。
此属性的初始值为 。False
注意:此值将覆盖 DIMZIN 系统变量的值。
Sub Example_SuppressTrailingZeros()
   ' uses the SuppressTrailingZeros property to toggle the display of trailing zeros
   ' in the dimension display
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 7: point2(1) = 5: point2(2) = 0
Toggle:
    Select Case MsgBox("Press OK to toggle the display of trailing zeros in the dimension", vbOKCancel)
        Case vbOK
            ' Toggle the display of trailing zeros for the dimension value
            dimObj.SuppressTrailingZeros = Not (dimObj.SuppressTrailingZeros)
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
(defun c:Example_SuppressTrailingZeros()
    ;; uses the SuppressTrailingZeros property to toggle the display of trailing zeros
    ;; in the dimension display
    ;; Define the dimension
          point2 (vlax-3d-point 7 5 0)
    (vla-ZoomAll acadObj)
    ;; Toggle the display of trailing zeros for the dimension value
    (vla-put-SuppressTrailingZeros dimObj (if (= (vla-get-SuppressTrailingZeros dimObj) :vlax-true) :vlax-false :vlax-true))
    (alert "Suppression of trailing zeros toggled.")
    ;; Toggle the display of trailing zeros for the dimension value back to previous state
    (alert "Suppression of trailing zeros toggled back.")
GMT+8, 2026-11-13 13:55
