StartPoint 属性 (ActiveX)
指定圆弧、直线或椭圆的起点。 支持的平台:仅限 Windows 属性值只读:是,但 Line 对象除外,该对象是读写的 类型:变体(双打的三元素阵列) 表示对象起点的 3D 坐标。 言论![]() 圆弧、椭圆和直线的起点 不能更改圆弧或椭圆的起点。要编辑圆弧,请使用 和 属性。若要编辑椭圆,请使用 、 和 属性。EndAngleRadiusEndAngleMajorAxisRadiusRatio 例子VBA: Sub Example_StartPoint()
' This example creates an elliptical arc and then
' finds the coordinates of its start point and endpoint.
Dim ellObj As AcadEllipse
Dim majAxis(0 To 2) As Double
Dim center(0 To 2) As Double
Dim radRatio As Double
Dim startPoint As Variant
Dim endPoint As Variant
' Create an ellipse in model space
center(0) = 5#: center(1) = 5#: center(2) = 0#
majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
radRatio = 0.3
Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
' Enter a start angle of 45 degrees, and an end angle of 270 degrees
ellObj.startAngle = 45 * (3.14 / 180)
ellObj.endAngle = 270 * (3.14 / 180)
ZoomAll
' Find the start and endpoints for the ellipse
startPoint = ellObj.startPoint
endPoint = ellObj.endPoint
MsgBox "This ellipse has a start point of " & _
startPoint(0) & ", " & startPoint(1) & ", " & _
startPoint(2) & " and an endpoint of " & _
endPoint(0) & ", " & endPoint(1) & ", " & _
endPoint(2), vbInformation, "StartPoint Example"
可视化 LISP: (vl-load-com)
(defun c:Example_StartPoint()
;; This example creates an elliptical arc and then
;; finds the coordinates of its start and end points.
;; Create an ellipse in model space
(setq center (vlax-3d-point 5 5 0)
majAxis (vlax-3d-point 10 20 0)
radRatio 0.3)
(setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio))
;; Enter a start angle of 45 degrees, and an end angle of 270 degrees
(vla-put-StartAngle ellObj (* 45 (/ 3.14 180)))
(vla-put-EndAngle ellObj (* 270 (/ 3.14 180)))
(vla-ZoomAll acadObj)
;; Find the start and endpoints for the ellipse
(setq startPoint (vlax-safearray->list (vlax-variant-value (vla-get-StartPoint ellObj))))
(setq endPoint (vlax-safearray->list (vlax-variant-value (vla-get-EndPoint ellObj))))
(alert (strcat "This ellipse has a start point of " (rtos (nth 0 startPoint) 2) ", "
(rtos (nth 1 startPoint) 2) ", "
(rtos (nth 2 startPoint) 2) " and an endpoint of "
(rtos (nth 0 endPoint) 2) ", "
(rtos (nth 1 endPoint) 2) ", "
(rtos (nth 2 endPoint) 2)))
GMT+8, 2026-11-14 14:19
