StartAngle 属性 (ActiveX)
指定圆弧或椭圆的起始角度。 支持的平台:仅限 Windows 属性值只读:不 类型:双 以弧度为单位的起始角。 言论![]() 例子VBA: Sub Example_StartAngle()
' This example creates an ellipse and enters the start and
' end angles to create an elliptical arc.
Dim ellObj As AcadEllipse
Dim majAxis(0 To 2) As Double
Dim center(0 To 2) As Double
Dim radRatio As Double
' Create an ellipse in model space
center(0) = 5#: center(1) = 5#: center(2) = 0#
majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
radRatio = 0.3
Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
'Enter a start angle of 45 degrees, and an end angle of 270 degrees
ellObj.startAngle = 45 * (3.14 / 180)
ellObj.endAngle = 270 * (3.14 / 180)
ZoomAll
MsgBox "The ellipse has a start angle of " & ellObj.startAngle * (180 / 3.14) & " and the end angle of " & ellObj.endAngle * (180 / 3.14) & " degrees.", vbInformation, "StartAngle Example"
可视化 LISP: (vl-load-com)
(defun c:Example_StartAngle()
;; This example creates an ellipse and enters the start and
;; end angles to create an elliptical arc.
;; Create an ellipse in model space
(setq center (vlax-3d-point 5 5 0)
majAxis (vlax-3d-point 10 20 0)
radRatio 0.3)
(setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio))
;; Enter a start angle of 45 degrees, and an end angle of 270 degrees
(vla-put-StartAngle ellObj (* 45 (/ 3.14 180)))
(vla-put-EndAngle ellObj (* 270 (/ 3.14 180)))
(vla-ZoomAll acadObj)
(alert (strcat "This ellipse has a start angle of " (rtos (* (vla-get-StartAngle ellObj) (/ 180 3.14)) 2) " and the end angle of " (rtos (* (vla-get-EndAngle ellObj) (/ 180 3.14)) 2) " degrees."))
GMT+8, 2026-11-16 16:09
