SnapRotationAngle 属性 (ActiveX)
指定视口相对于当前 UCS 的捕捉旋转角度。 支持的平台:仅限 Windows 属性值只读:不 类型:双 以弧度为单位的角度。有效范围为 0 到 6.28。 言论不能更改活动图纸空间视口的对齐基点。 在执行对 or 方法的调用之前,对此属性的更改不会反映在图形中。UpdateRegen 注意:此属性的值存储在 SNAPANG 系统变量中。
例子VBA: Sub Example_SnapRotationAngle()
' This example changes the snap rotation angle for a
' model space and paper space viewport.
' Create a new model space viewport
Dim viewportObj As AcadViewport
Set viewportObj = ThisDrawing.Viewports.Add("NewViewport")
' Find the current snap rotation angle
Dim currSnapAngle As Double
currSnapAngle = viewportObj.SnapRotationAngle
MsgBox "The current model space snap rotation angle is " & viewportObj.SnapRotationAngle, , "SnapRotationAngle Example"
' Change the snap rotation angle
viewportObj.SnapRotationAngle = 1.5
MsgBox "The new model space snap rotation angle is " & viewportObj.SnapRotationAngle, , "SnapRotationAngle Example"
' Create a new paper space viewport
Dim pviewportObj As AcadPViewport
Dim center(0 To 2) As Double
Dim width As Double
Dim height As Double
center(0) = 3: center(1) = 3: center(2) = 0
width = 40
height = 40
ThisDrawing.ActiveSpace = acPaperSpace
Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
currSnapAngle = pviewportObj.SnapRotationAngle
MsgBox "The current paper space snap rotation angle is " & pviewportObj.SnapRotationAngle, , "SnapRotationAngle Example"
pviewportObj.SnapRotationAngle = 1.5
MsgBox "The new paper space snap base point is " & pviewportObj.SnapRotationAngle, , "SnapRotationAngle Example"
可视化 LISP: (vl-load-com)
(defun c:Example_SnapRotationAngle()
;; This example changes the snap rotation angle for a
;; model space and paper space viewport.
;; Create a new model space viewport
(setq viewportObj (vla-Add (vla-get-Viewports doc) "NewViewport"))
;; Find the current snap rotation angle
(setq currSnapAngle (vla-get-SnapRotationAngle viewportObj))
(alert (strcat "The current model space snap rotation angle is " (rtos currSnapAngle 2)))
;; Change the snap rotation angle
(vla-put-SnapRotationAngle viewportObj 1.5)
(alert (strcat "The new model space snap rotation angle is " (rtos (vla-get-SnapRotationAngle viewportObj) 2)))
;; Create a new paper space viewport
(setq center (vlax-3d-point 3 3 0)
width 40
height 40)
(vla-put-ActiveSpace doc acPaperSpace)
(setq paperSpace (vla-get-PaperSpace doc))
(setq pviewportObj (vla-AddPViewport paperSpace center width height))
(setq currSnapAngle (vla-get-SnapRotationAngle pviewportObj))
(alert (strcat "The current paper space snap rotation angle is " (rtos currSnapAngle 2)))
(vla-put-SnapRotationAngle pviewportObj 1.5)
(alert (strcat "The new paper space snap base point is " (rtos (vla-get-SnapRotationAngle pviewportObj) 2)))
GMT+8, 2026-11-12 12:54
