SnapOn 属性 (ActiveX)
指定捕捉的状态。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论SnapOn使用当前对齐网格分辨率、旋转和样式激活对齐模式。若要更改捕捉栅格分辨率,请使用以下方法。若要更改对齐旋转,请使用属性。SetSnapSpacingSnapRotationAngle 捕捉网格是不可见的。使用该属性可显示单独的可见网格。GridOn AutoCAD 会忽略透视图中的“捕捉”模式。 注意:此属性的值存储在 SNAPMODE 系统变量中。要更改捕捉样式,请使用 SNAPSTYL 系统变量。
例子VBA: Sub Example_SnapOn()
' This example toggles the setting of SnapOn.
Dim viewportObj As AcadViewport
' Set the viewportObj variable to the activeviewport
Set viewportObj = ThisDrawing.ActiveViewport
' Display the current setting of SnapOn
MsgBox "Snap mode is: " & IIf(viewportObj.SnapOn, "On", "Off"), , "SnapOn Example"
' Toggle the setting of SnapOn
viewportObj.SnapOn = Not (viewportObj.SnapOn)
' Reset the active viewport to see the change on the AutoCAD status bar
ThisDrawing.ActiveViewport = viewportObj
MsgBox "Snap mode is now: " & IIf(viewportObj.SnapOn, "On", "Off"), , "SnapOn Example"
可视化 LISP: (vl-load-com)
(defun c:Example_SnapOn()
;; This example toggles the setting of SnapOn.
;; Set the viewportObj variable to the activeviewport
(setq viewportObj (vla-get-ActiveViewport doc))
;; Display the current setting of SnapOn
(alert (strcat "Snap mode is: " (if (= (vla-get-SnapOn viewportObj) :vlax-true) "On" "Off")))
;; Toggle the setting of SnapOn
(vla-put-SnapOn viewportObj (if (= (vla-get-SnapOn viewportObj) :vlax-true) :vlax-false :vlax-true))
;; Reset the active viewport to see the change on the AutoCAD status bar
(vla-put-ActiveViewport doc viewportObj)
(alert (strcat "Snap mode is now: " (if (= (vla-get-SnapOn viewportObj) :vlax-true) "On" "Off")))
GMT+8, 2026-11-12 12:24
