SnapBasePoint 属性 (ActiveX)
指定视口的对齐基点。 支持的平台:仅限 Windows 属性值只读:不 类型:变体(双精度的双元素数组) 表示视口的捕捉基点的 2D WCS 坐标。 言论不能更改活动图纸空间视口的对齐基点。 在执行对 or 方法的调用之前,对此属性的更改不会反映在显示中。UpdateRegen 注意:此属性的值存储在 SNAPBASE 系统变量中。
例子VBA: Sub Example_SnapBasePoint()
' This example changes the snap base point for a
' model space and paper space viewport.
' Create a new model space viewport
Dim viewportObj As AcadViewport
Set viewportObj = ThisDrawing.Viewports.Add("NewViewport")
' Find the current snap base point
Dim currSnapPnt As Variant
currSnapPnt = viewportObj.SnapBasePoint
MsgBox "The current model space snap base point is " & viewportObj.SnapBasePoint(0) & ", " & viewportObj.SnapBasePoint(1), , "SnapBasePoint Example"
' Change the snap base point
Dim newSnapPnt(0 To 1) As Double
newSnapPnt(0) = 5#: newSnapPnt(1) = 5#
viewportObj.SnapBasePoint = newSnapPnt
MsgBox "The new model space snap base point is " & viewportObj.SnapBasePoint(0) & ", " & viewportObj.SnapBasePoint(1), , "SnapBasePoint Example"
' Create a new paper space viewport
Dim pviewportObj As AcadPViewport
Dim center(0 To 2) As Double
Dim width As Double
Dim height As Double
center(0) = 3: center(1) = 3: center(2) = 0
width = 40
height = 40
ThisDrawing.ActiveSpace = acPaperSpace
Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
currSnapPnt = pviewportObj.SnapBasePoint
MsgBox "The current paper space snap base point is " & pviewportObj.SnapBasePoint(0) & ", " & pviewportObj.SnapBasePoint(1), , "SnapBasePoint Example"
newSnapPnt(0) = 2#: newSnapPnt(1) = 2#
pviewportObj.SnapBasePoint = newSnapPnt
MsgBox "The new paper space snap base point is " & pviewportObj.SnapBasePoint(0) & ", " & pviewportObj.SnapBasePoint(1), , "SnapBasePoint Example"
可视化 LISP: (vl-load-com)
(defun c:Example_SnapBasePoint()
;; This example changes the snap base point for a
;; model space and paper space viewport.
;; Create a new model space viewport
(setq viewportObj (vla-Add (vla-get-Viewports doc) "NewViewport"))
;; Find the current snap base point
(setq currSnapPnt (vlax-variant-value (vla-get-SnapBasePoint viewportObj)))
(alert (strcat "The current model space snap base point is " (rtos (vlax-safearray-get-element currSnapPnt 0) 2) ", "
(rtos (vlax-safearray-get-element currSnapPnt 1) 2)))
;; Change the snap base point
(setq newSnapPnt (vlax-make-safearray vlax-vbDouble '(0 . 1)))
(vlax-safearray-fill newSnapPnt '(5 5))
(vla-put-SnapBasePoint viewportObj newSnapPnt)
(alert (strcat "The new model space snap base point is " (rtos (vlax-safearray-get-element newSnapPnt 0) 2) ", "
(rtos (vlax-safearray-get-element newSnapPnt 1) 2)))
;; Create a new paper space viewport
(setq center (vlax-3d-point 3 3 0)
width 40
height 40)
(vla-put-ActiveSpace doc acPaperSpace)
(setq paperSpace (vla-get-PaperSpace doc))
(setq pviewportObj (vla-AddPViewport paperSpace center width height))
(setq currSnapPnt (vlax-variant-value (vla-get-SnapBasePoint pviewportObj)))
(alert (strcat "The current paper space snap base point is " (rtos (vlax-safearray-get-element currSnapPnt 0) 2) ", "
(vlax-safearray-fill newSnapPnt '(2 2))
(vla-put-SnapBasePoint pviewportObj newSnapPnt)
(alert (strcat "The new paper space snap base point is " (rtos (vlax-safearray-get-element newSnapPnt 0) 2) ", "
GMT+8, 2026-11-13 13:28
