ShowRotation 属性 (ActiveX)
确定地理地图图像、栅格图像或擦拭是否在其旋转值处显示。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_ShowRotation()
' This example adds a raster image in model space and rotates the image.
' One rotation is done without angle limits, one is done with ShowRotation,
' which limits rotations to 90 degrees
' This example uses the "downtown.jpg" found in the sample
' directory. If you do not have this image, or it is located
' in a different directory, insert a valid path and file name
' for the imageName variable below.
Dim scalefactor As Double, rotationAngle As Double
Dim imageName As String
Dim rasterObj As AcadRasterImage
imageName = "c:\Autocad\sample\downtown.jpg"
' Define Raster object
insertionPoint(0) = 5: insertionPoint(1) = 5: insertionPoint(2) = 0
scalefactor = 1#: rotationAngle = 0
On Error GoTo ERRORTRAP
' Loads a raster image into model space
Set rasterObj = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotationAngle)
' Limit the raster image rotations to 90 degrees
rasterObj.ShowRotation = True
' Rotate the raster image 180 degrees
rasterObj.Rotate insertionPoint, 180
Exit Sub
' If you get an error (most likely a problem with the file path),
' then display an error message
ERRORTRAP:
If Err.Description <> "" Then
MsgBox Err.Description
End If
可视化 LISP: (vl-load-com)
(defun c:Example_ShowRotation()
;; This example adds a raster image in model space and rotates the image.
;; One rotation is done without angle limits, one is done with ShowRotation,
;; which limits rotations to 90 degrees
;; This example uses the "2d Projected Polylines.jpg" found in the sample
;; directory. If you do not have this image, or it is located
;; in a different directory, insert a valid path and file name
;; for the imageName variable below.
;; Define Raster object
(setq insertionPoint (vlax-3d-point 5 5 0)
imageName ".\\Sample\\VBA\\2d Projected Polylines.jpg"
scalefactor 1
rotationAngle 0)
;; Loads a raster image into model space
(if (/= (findfile imageName) nil)
(progn
(setq rasterObj (vla-AddRaster modelSpace (findfile imageName) insertionPoint scalefactor rotationAngle))
;; Limit the raster image rotations to 90 degrees
(vla-put-ShowRotation rasterObj :vlax-true)
;; Rotate the raster image 180 degrees
(vla-Rotate rasterObj insertionPoint 180)
(vla-ZoomExtents acadObj)
(alert (strcat imageName " could not be found."))
GMT+8, 2026-11-13 17:22
