ShowRasterImage 属性 (ActiveX)
控制实时平移和缩放期间光栅图像的显示。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。False 如果拖动显示处于打开状态,并且您启用了 ,则在重新定位原始图像时,图像的副本将随光标移动。ShowRasterImage 注意:此属性的此值存储在 RTDISPLAY 系统变量中。
例子VBA: Sub Example_ShowRasterImage()
' ShowRasterImage. It then changes the value, and finally
Dim currShowRasterImage As Boolean
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current ShowRasterImage value
currShowRasterImage = preferences.DISPLAY.ShowRasterImage
MsgBox "The current value for ShowRasterImage is " & preferences.DISPLAY.ShowRasterImage, vbInformation, "ShowRasterImage Example"
' Change the value for ShowRasterImage
preferences.DISPLAY.ShowRasterImage = Not (currShowRasterImage)
MsgBox "The new value for ShowRasterImage is " & preferences.DISPLAY.ShowRasterImage, vbInformation, "ShowRasterImage Example"
' Reset ShowRasterImage to its original value
preferences.DISPLAY.ShowRasterImage = currShowRasterImage
MsgBox "The ShowRasterImage value is reset to " & preferences.DISPLAY.ShowRasterImage, vbInformation, "ShowRasterImage Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ShowRasterImage()
;; ShowRasterImage. It then changes the value, and finally
;; Retrieve the current ShowRasterImage value
(setq currShowRasterImage (vla-get-ShowRasterImage (vla-get-Display preferences)))
(alert (strcat "The current value for ShowRasterImage is " (if (= currShowRasterImage :vlax-true) "True" "False")))
;; Change the value for ShowRasterImage
(vla-put-ShowRasterImage (vla-get-Display preferences) (if (= currShowRasterImage :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The new value for ShowRasterImage is " (if (= (vla-get-ShowRasterImage (vla-get-Display preferences)) :vlax-true) "True" "False")))
;; Reset ShowRasterImage to its original value
(vla-put-ShowRasterImage (vla-get-Display preferences) currShowRasterImage)
(alert (strcat "The ShowRasterImage value is reset to " (if (= (vla-get-ShowRasterImage (vla-get-Display preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-11-14 14:41
