ShortCutMenuDisplay 属性 (ActiveX)
控制在绘图区域中单击鼠标右键是否显示快捷菜单或发出 Enter 键。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。True 当此属性设置为 时,可以使用对象中的属性自定义在绘图区域中单击鼠标右键的功能。TruePreferencesUser 注意:此属性的值存储在 SHORTCUTMENU 系统变量中。
例子VBA: Sub Example_ShortCutMenuDisplay()
' This example reads and toggles the preference value which controls
' whether right-clicking in the drawing area displays a shortcut menu
' or issues ENTER.
Dim ACADPref As AcadPreferencesUser
Dim newAction As String
' Get the drafting preferences object
Set ACADPref = ThisDrawing.Application.Preferences.User
originalValue = ACADPref.ShortCutMenuDisplay
newAction = IIf(originalValue, "displays the shortcut menu", "sends an ENTER keystroke to ACAD")
MsgBox "Right-clicking the mouse CURRENTLY " & newAction, vbInformation
' Modify the AutoSnapMarker preference by toggling the value
ACADPref.ShortCutMenuDisplay = Not (originalValue)
newValue = ACADPref.ShortCutMenuDisplay
newAction = IIf(newValue, "display the shortcut menu", "send an ENTER keystroke to ACAD")
MsgBox "Right-clicking the mouse over the drawing WILL NOW " & newAction, vbInformation
可视化 LISP: (vl-load-com)
(defun c:Example_ShortCutMenuDisplay()
;; This example reads and toggles the preference value which controls
;; whether right-clicking in the drawing area displays a shortcut menu
;; or issues ENTER.
(setq originalValue (vla-get-ShortCutMenuDisplay (vla-get-User preferences)))
(setq newAction (if (= originalValue :vlax-true) "displays the shortcut menu" "sends an ENTER keystroke to ACAD"))
(alert (strcat "Right-clicking the mouse CURRENTLY " newAction))
;; Modify the AutoSnapMarker preference by toggling the value
(vla-put-ShortCutMenuDisplay (vla-get-User preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-ShortCutMenuDisplay (vla-get-User preferences)))
(setq newAction (if (= newValue :vlax-true) "displays the shortcut menu" "sends an ENTER keystroke to ACAD"))
(alert (strcat "Right-clicking the mouse over the drawing WILL NOW " newAction))
GMT+8, 2026-11-16 16:18
