ShortcutMenu 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 796| 评论: 0|原作者: admin|来自: AutoCAD
确定指定的弹出菜单是否为快捷菜单。
object.ShortcutMenu
类型:PopupMenu
此属性应用于的对象。
只读:是的
类型:布尔
  • True:这是快捷菜单。
  • False:这不是快捷菜单。
Sub Example_ShortcutMenu()
    ' This example iterates through the menus collection and
    ' determines if each menu is the shortcut menu.
    ' Note that depending on how many menus are currently loaded, the
    ' menuStatus string may not be displayed in full.
    Dim currMenu As AcadPopupMenu
    Dim menuStatus As String
    menuStatus = ""
    For Each currMenu In ThisDrawing.Application.MenuGroups.Item(0).Menus
    If currMenu.shortcutMenu Then
        menuStatus = menuStatus & currMenu.name & " is the shortcut menu." & vbCrLf
    Else
        menuStatus = menuStatus & currMenu.name & " is not the shortcut menu." & vbCrLf
    End If
    Next currMenu
    MsgBox menuStatus
(defun c:Example_ShortcutMenu()
    ;; This example iterates through the menus collection and
    ;; determines if each menu is the shortcut menu.
    ;; Note that depending on how many menus are currently loaded, the
    ;; menuStatus string may not be displayed in full.
    (setq menuStatus "")
    (vlax-for currMenu (vla-get-Menus (vla-Item (vla-get-MenuGroups acadObj) 0))
        (if (= (vla-get-ShortcutMenu currMenu) :vlax-true)
            (setq menuStatus (strcat menuStatus (vla-get-Name currMenu) " is a shortcut menu.\n"))
            (setq menuStatus (strcat menuStatus (vla-get-Name currMenu) " is not a shortcut menu.\n"))
    (alert menuStatus)
GMT+8, 2026-11-12 12:18
