SegmentPerPolyline 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 985| 评论: 0|原作者: admin|来自: AutoCAD
指定要为每条折线曲线生成的线段数。
object.SegmentPerPolyline
类型:DatabasePreferences
此属性应用于的对象。
只读:不
类型:长
要为每条折线曲线生成的线段数。
0 < <= 42950SegmentPerPolyline
初始值为 8。指定的数字越大,对性能的影响就越大。
注意:此属性的值存储在 SPLINESEGS 系统变量中。
Sub Example_SegmentPerPolyline()
    ' SegmentPerPolyline. It then changes the value, and finally
    Dim currSegmentPerPolyline As Integer
    Dim newSegmentPerPolyline As Integer
    ' Retrieve the current SegmentPerPolyline value
    currSegmentPerPolyline = ThisDrawing.preferences.SegmentPerPolyline
    MsgBox "The current value for SegmentPerPolyline is " & currSegmentPerPolyline, vbInformation, "SegmentPerPolyline Example"
    ' Change the value for SegmentPerPolyline
    newSegmentPerPolyline = 2001
    ThisDrawing.preferences.SegmentPerPolyline = newSegmentPerPolyline
    MsgBox "The new value for SegmentPerPolyline is " & newSegmentPerPolyline, vbInformation, "SegmentPerPolyline Example"
    ' Reset SegmentPerPolyline to its original value
    ThisDrawing.preferences.SegmentPerPolyline = currSegmentPerPolyline
    MsgBox "The SegmentPerPolyline value is reset to " & currSegmentPerPolyline, vbInformation, "SegmentPerPolyline Example"
(defun c:Example_SegmentPerPolyline()
    ;; SegmentPerPolyline. It then changes the value, and finally
    (setq preferences (vla-get-Preferences doc))
    ;; Retrieve the current SegmentPerPolyline value
    (setq currSegmentPerPolyline (vla-get-SegmentPerPolyline preferences))
    (alert (strcat "The current value for SegmentPerPolyline is " (itoa currSegmentPerPolyline)))
    ;; Change the value for SegmentPerPolyline
    (setq newSegmentPerPolyline 2001)
    (vla-put-SegmentPerPolyline preferences newSegmentPerPolyline)
    (alert (strcat "The new value for SegmentPerPolyline is " (itoa newSegmentPerPolyline)))
    ;; Reset SegmentPerPolyline to its original value
    (vla-put-SegmentPerPolyline preferences currSegmentPerPolyline)
    (alert (strcat "The SegmentPerPolyline value is reset to " (itoa currSegmentPerPolyline)))
GMT+8, 2026-11-14 14:47
