SCMDefaultMode 属性 (ActiveX)
在“默认”模式下确定绘图区域中的右键单击功能,这意味着未选择任何对象,也未执行任何命令。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举AcDrawingAreaSCMDefault
言论此属性的初始值为 。acSCM 仅当该属性设置为 时,才能设置此属性。ShortcutMenuDisplayTrue 注意:此属性的值存储在 SHORTCUTMENU 系统变量中。
例子VBA: Sub Example_SCMDefaultMode()
' This example reads and modifies the SCMDefaultMode
' preference value.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesUser
Dim originalValue As Integer, newValue As Integer
' Get the user preferences object
Set ACADPref = ThisDrawing.Application.Preferences.User
originalValue = ACADPref.SCMDefaultMode
MsgBox "The SCMDefaultMode preference is set to: " & originalValue
' Modify the SCMDefaultMode preference by toggling the value
ACADPref.SCMDefaultMode = acRepeatLastCommand
MsgBox "The SCMDefaultMode preference has been set to: " & ACADPref.SCMDefaultMode
ACADPref.SCMDefaultMode = originalValue
MsgBox "The SCMDefaultMode preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_SCMDefaultMode()
;; This example reads and modifies the SCMDefaultMode
;; preference value.
;; When finished, this example resets the preference value back to
;; its original value.
(setq originalValue (vla-get-SCMDefaultMode (vla-get-User preferences)))
(alert (strcat "The SCMDefaultMode preference is set to: " (itoa originalValue)))
;; Modify the SCMDefaultMode preference by toggling the value
(vla-put-SCMDefaultMode (vla-get-User preferences) acRepeatLastCommand)
(alert (strcat "The SCMDefaultMode preference has been set to: " (itoa (vla-get-SCMDefaultMode (vla-get-User preferences)))))
(vla-put-SCMDefaultMode (vla-get-User preferences) originalValue)
(alert (strcat "The SCMDefaultMode preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-11-14 14:44
