Saved 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 582| 评论: 0|原作者: admin|来自: AutoCAD
Saved 属性 (ActiveX)
指定文档是否有任何未保存的更改。
object.Saved
类别: 文档
此属性应用于的对象。
只读:是的
类型:布尔
  • True:文档没有未保存的更改。
  • False:文档有未保存的更改。
Sub Example_Saved()
    ' This example checks to see if the current drawing has been modified.
    If Not ThisDrawing.Saved Then
        MsgBox "Drawing has been modified! Use the Save or SaveAs method to save the drawing.", , "Saved Example"
    Else
        MsgBox "Drawing has not been modified since the last save.", , "Saved Example"
    End If
(defun c:Example_Saved()
    ;; This example checks to see if the current drawing has been modified.
    (if (= (vla-get-Saved doc) :vlax-false)
        (alert "Drawing has been modified! Use the Save or SaveAs method to save the drawing.")
        (alert "Drawing has not been modified since the last save.")
GMT+8, 2026-10-15 12:54
