RoundDistance 属性 (ActiveX)
指定尺寸单位的舍入。 支持的平台:仅限 Windows 签名VBA: object.RoundDistance
属性值只读:不 类型:双 一个正实数,表示要将距离舍入到的值。初始值为 0.00。 言论此属性将所有尺寸标注距离舍入到指定值。例如,如果此属性设置为 0.25,则距离将舍入到最接近的 0.25 单位。如果将此属性设置为 1.0,则维度的距离将舍入到最接近的整数。请注意,小数点后编辑的位数取决于属性或 DIMDEC 系统变量设置的精度。此属性不适用于角度尺寸。PrimaryUnitsPrecision 注意:此属性将覆盖给定维度的 DIMRND 系统变量的值。
例子VBA: Sub Example_RoundDistance()
' uses RoundDistance to set the unit display
' of the dimension to rounded values
Dim dimObj As AcadDimAligned
' Define the dimension
point2(0) = 10.123: point2(1) = 5: point2(2) = 0
MsgBox "Press any key to round the dimension unit display to .5"
' Round the distance of the dimension to 0.50 of a unit
dimObj.RoundDistance = 0.5
MsgBox "Dimension units have been rounded to: " & dimObj.RoundDistance
可视化 LISP: (vl-load-com)
(defun c:Example_RoundDistance()
;; uses RoundDistance to set the unit display
;; of the dimension to rounded values
;; Define the dimension
point2 (vlax-3d-point 10.123 5 0)
(vla-ZoomAll acadObj)
(alert "Dimensions value will now be rounded to the nearest 0.50 of a unit")
;; Round the distance of the dimension to 0.50 of a unit
(vla-put-RoundDistance dimObj 0.5)
(alert (strcat "Dimension units have been rounded to: " (rtos (vla-get-RoundDistance dimObj) 2)))
GMT+8, 2026-11-14 14:56
