RemoveHiddenLines 属性 (ActiveX)
指定是否要在图纸空间视口上绘制隐藏线。(已过时) 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性已过时,将在将来的版本中删除。 例子VBA: Sub Example_RemoveHiddenLines()
' This example creates a new paper space viewport.
' It then displays the value of RemoveHiddenLines for the viewport.
Dim pviewportObj As AcadPViewport
Dim center(0 To 2) As Double
Dim width As Double
Dim height As Double
' Define the paper space viewport
center(0) = 3: center(1) = 3: center(2) = 0
width = 40
height = 40
' Change from model space to paper space
ThisDrawing.ActiveSpace = acPaperSpace
' Create the paper space viewport
Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
pviewportObj.DISPLAY True
ThisDrawing.mspace = True
ThisDrawing.ActivePViewport = pviewportObj
' Find the value for RemoveHiddenLines for the viewport
Dim removeHidden As Boolean
removeHidden = pviewportObj.RemoveHiddenLines
MsgBox "The value of the RemoveHiddenLines property for the paperspace viewport is " & pviewportObj.RemoveHiddenLines, , "RemoveHiddenLines Example"
可视化 LISP: (vl-load-com)
(defun c:Example_RemoveHiddenLines()
;; This example creates a new paper space viewport.
;; It then displays the value of ShadePlot for the viewport.
;; ShadePlot replaces RemoveHiddenLines.
;; Define the paper space viewport
(setq center (vlax-3d-point 3 3 0)
width 40
height 40)
;; Change from model space to paper space
(vla-put-ActiveSpace doc acPaperSpace)
;; Create the paper space viewport
(setq paperSpace (vla-get-PaperSpace doc))
(setq pviewportObj (vla-AddPViewport paperSpace center width height))
(vla-Display pviewportObj :vlax-true)
(vla-put-MSpace doc :vlax-true)
(vla-put-ActivePViewport doc pviewportObj)
;; Find the value for ShadePlot for the viewport
(alert (strcat "The value of the ShadePlot property for the paperspace viewport is " (itoa (vla-get-ShadePlot pviewportObj))))
GMT+8, 2026-11-13 17:21
