ProxyImage 属性 (ActiveX)
控制在图形中在第三方应用程序中创建的对象的显示。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acProxyImage
言论此属性的初始值为 。acProxyShow 例子VBA: Sub Example_ProxyImage()
' ProxyImage. It then changes the value, and finally
Dim currProxyImage As Integer
Dim constant As String
Dim newConstant As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current ProxyImage value
currProxyImage = preferences.OpenSave.ProxyImage
constant = Choose(currProxyImage + 1, "acProxyNotShow", "acProxyShow", "acProxyBoundingBox")
MsgBox "The current value for ProxyImage is " & constant, vbInformation, "ProxyImage Example"
' Change the value for ProxyImage
newConstant = "acProxyBoundingBox"
preferences.OpenSave.ProxyImage = acProxyBoundingBox
MsgBox "The new value for ProxyImage is " & newConstant, vbInformation, "ProxyImage Example"
' Reset ProxyImage to its original value
preferences.OpenSave.ProxyImage = currProxyImage
MsgBox "The ProxyImage value is reset to " & constant, vbInformation, "ProxyImage Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ProxyImage()
;; ProxyImage. It then changes the value, and finally
;; Retrieve the current ProxyImage value
(setq currProxyImage (vla-get-ProxyImage (vla-get-OpenSave preferences)))
(setq constant (cond
((= currProxyImage 0) "acProxyNotShow")
((= currProxyImage 1) "acProxyShow")
((= currProxyImage 2) "acProxyBoundingBox")
(alert (strcat "The current value for ProxyImage is " constant))
;; Change the value for ProxyImage
(setq newConstant "acProxyBoundingBox")
(vla-put-ProxyImage (vla-get-OpenSave preferences) acProxyBoundingBox)
(alert (strcat "The new value for ProxyImage is " newConstant))
;; Reset ProxyImage to its original value
(vla-put-ProxyImage (vla-get-OpenSave preferences) currProxyImage)
(alert (strcat "The ProxyImage value is reset to " constant))
GMT+8, 2026-11-12 12:22
