PrintFile 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 852| 评论: 0|原作者: admin|来自: AutoCAD
指定用于临时打印文件名的备用名称。
object.PrintFile
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
打印文件的备用名称。输入“.”以使用默认值(当前图形名称)。输入备用打印文件的驱动器、路径和文件名。
默认名称是图形的名称,加上文件扩展名 .plt。
Sub Example_PrintFile()
    ' PrintFile. It then changes the value, and finally
    Dim currPrintFile As String
    Dim newPrintFile As String
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current PrintFile value
    currPrintFile = preferences.Files.PrintFile
    MsgBox "The current value for PrintFile is " & currPrintFile, vbInformation, "PrintFile Example"
    ' Change the value for PrintFile
    newPrintFile = "TestPrintFile.plt"
    preferences.Files.PrintFile = newPrintFile
    MsgBox "The new value for PrintFile is " & newPrintFile, vbInformation, "PrintFile Example"
    ' Reset PrintFile to its original value
    preferences.Files.PrintFile = currPrintFile
    MsgBox "The PrintFile value is reset to " & currPrintFile, vbInformation, "PrintFile Example"
(defun c:Example_PrintFile()
    ;; PrintFile. It then changes the value, and finally
    ;; Retrieve the current PrintFile value
    (setq currPrintFile (vla-get-PrintFile (vla-get-Files preferences)))
    (alert (strcat "The current value for PrintFile is " currPrintFile))
    ;; Change the value for PrintFile
    (setq newValue "TestPrintFile.plt")
    (vla-put-PrintFile (vla-get-Files preferences) newValue)
    (alert (strcat "The new value for PrintFile is " newValue))
    ;; Reset PrintFile to its original value
    (vla-put-PrintFile (vla-get-Files preferences) currPrintFile)
    (alert (strcat "The PrintFile value is reset to " currPrintFile))
GMT+8, 2026-11-13 13:09
