PostScriptPrologFile 属性 (ActiveX)
指定 acad.psf 文件中自定义 prolog 部分的名称。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 执行 PSOUT 时要使用的 acad.psf 文件的 postscript prolog 部分的名称。 言论prolog 截面与 PSOUT AutoCAD 命令一起使用,以自定义生成的输出。有关详细信息,请参见 AutoCAD 文档。 注意:此属性的值存储在 PSPROLOG 系统变量中。
例子VBA: Sub Example_PostScriptPrologFile()
' PostScriptPrologFile. It then changes the value, and finally
Dim currPostScriptPrologFile As String
Dim newPostScriptPrologFile As String
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current PostScriptPrologFile value
currPostScriptPrologFile = preferences.Files.PostScriptPrologFile
If currPostScriptPrologFile = "" Then
MsgBox "PostScriptPrologFile is not currently set.", vbInformation, "PostScriptPrologFile Example"
Else
MsgBox "The current value for PostScriptPrologFile is " & currPostScriptPrologFile, vbInformation, "PostScriptPrologFile Example"
End If
' Change the value for PostScriptPrologFile
newPostScriptPrologFile = "TestPostScriptPrologFile"
preferences.Files.PostScriptPrologFile = newPostScriptPrologFile
MsgBox "The new value for PostScriptPrologFile is " & newPostScriptPrologFile, vbInformation, "PostScriptPrologFile Example"
' Reset PostScriptPrologFile to its original value
preferences.Files.PostScriptPrologFile = currPostScriptPrologFile
MsgBox "PostScriptPrologFile is reset to NULL.", vbInformation, "PostScriptPrologFile Example"
Else
MsgBox "The PostScriptPrologFile value is reset to " & currPostScriptPrologFile, vbInformation, "PostScriptPrologFile Example"
End If
可视化 LISP: (vl-load-com)
(defun c:Example_PostScriptPrologFile()
;; PostScriptPrologFile. It then changes the value, and finally
;; Retrieve the current PostScriptPrologFile value
(setq currPostScriptPrologFile (vla-get-PostScriptPrologFile (vla-get-Files preferences)))
(if (= currPostScriptPrologFile "")
(alert "PostScriptPrologFile is not currently set.")
(alert (strcat "The current value for PostScriptPrologFile is " currPostScriptPrologFile))
;; Change the value for PostScriptPrologFile
(setq newPostScriptPrologFile "TestPostScriptPrologFile")
(vla-put-PostScriptPrologFile (vla-get-Files preferences) newPostScriptPrologFile)
(alert (strcat "The new value for PostScriptPrologFile is " newPostScriptPrologFile))
;; Reset PostScriptPrologFile to its original value
(vla-put-PostScriptPrologFile (vla-get-Files preferences) currPostScriptPrologFile)
(alert "PostScriptPrologFile is reset to NULL.")
(alert (strcat "The PostScriptPrologFile value is reset to " currPostScriptPrologFile))
GMT+8, 2026-11-12 12:54
