PolarTrackingVector 属性 (ActiveX)
切换极坐标跟踪矢量的显示。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。True 注意:此属性的值存储在 TRACKPATH 系统变量中。
例子VBA: Sub Example_PolarTrackingVector()
' This example reads and modifies the preference value that controls
' the display of polar tracking vectors.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesDrafting
' Get the drafting preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Drafting
originalValue = ACADPref.PolarTrackingVector
MsgBox "The PolarTrackingVector preference is set to: " & originalValue
' Modify the PolarTrackingVector preference by toggling the value
ACADPref.PolarTrackingVector = Not (originalValue)
newValue = ACADPref.PolarTrackingVector
MsgBox "The PolarTrackingVector preference has been set to: " & newValue
' this preference in effect
ACADPref.PolarTrackingVector = originalValue
MsgBox "The PolarTrackingVector preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_PolarTrackingVector()
;; This example reads and modifies the preference value that controls
;; the display of polar tracking vectors.
;; When finished, this example resets the preference value back to
;; its original value.
Set ACADPref = ThisDrawing.Application.preferences.Drafting
(setq originalValue (vla-get-PolarTrackingVector (vla-get-Drafting preferences)))
(alert (strcat "The PolarTrackingVector preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the PolarTrackingVector preference by toggling the value
(vla-put-PolarTrackingVector (vla-get-Drafting preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-PolarTrackingVector (vla-get-Drafting preferences)))
(alert (strcat "The PolarTrackingVector preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-PolarTrackingVector (vla-get-Drafting preferences) originalValue)
(alert (strcat "The PolarTrackingVector preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-11-14 14:29
