PlotStyleName 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 659| 评论: 0|原作者: admin|来自: AutoCAD
指定对象、对象组或图层的打印样式名称。
object.PlotStyleName
类型:所有图形对象、AttributeReference、Dimension、Group、Layer、MLeaderLeader、SubDMeshEdge、SubDMeshFace、SubDMeshVertex、SubEntity、SubEntSolidEdge、SubEntSolidFace、SubEntSolidNode、SubEntSolidVertex
此属性应用于的对象。
只读:不;只写对象除外Group
类型:字符串
对象的打印样式名称。
Sub Example_PlotStyleName()
    ' This example creates a circle in model space and then
    ' finds the current PlotStyleName for the circle.
    Dim circleObj As AcadCircle
    Dim radius As Double
    ' Define the circle
    centerPoint(0) = 0#: centerPoint(1) = 0#: centerPoint(2) = 0#
    radius = 5#
    ' Create the Circle object in model space
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
    ZoomAll
    ' Find the PlotStyleName for the circle
    MsgBox "The current PlotStyleName for the circle is " & circleObj.PlotStyleName
(defun c:Example_PlotStyleName()
    ;; This example creates a circle in model space and then
    ;; finds the current PlotStyleName for the circle.
    ;; Define the circle
    (setq centerPoint (vlax-3d-point 0 0 0)
          radius 5)
    ;; Create the Circle object in model space
    (setq circleObj (vla-AddCircle modelSpace centerPoint radius))
    (vla-ZoomAll acadObj)
    ;; Find the PlotStyleName for the circle
    (alert (strcat "The current PlotStyleName for the circle is " (vla-get-PlotStyleName circleObj)))
GMT+8, 2026-11-14 14:49
