PickGroup 属性 (ActiveX)
确定选取组中的单个对象是否选择整个组。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。False 例子VBA: Sub Example_PickGroup()
' This example reads and modifies the preference value that
' determines if picking a single object in a group selects the entire group.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesSelection
' Get the user preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Selection
originalValue = ACADPref.PickGroup
MsgBox "The PickGroup preference is set to: " & originalValue
' Modify the PickGroup preference by toggling the value
ACADPref.PickGroup = Not (ACADPref.PickGroup)
newValue = ACADPref.PickGroup
MsgBox "The PickGroup preference has been set to: " & newValue
' this preference in effect
ACADPref.PickGroup = originalValue
MsgBox "The PickGroup preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_PickGroup()
;; This example reads and modifies the preference value that
;; determines if picking a single object in a group selects the entire group.
;; When finished, this example resets the preference value back to
;; its original value.
(setq originalValue (vla-get-PickGroup (vla-get-Selection preferences)))
(alert (strcat "The PickGroup preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the PickGroup preference by toggling the value
(vla-put-PickGroup (vla-get-Selection preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-PickGroup (vla-get-Selection preferences)))
(alert (strcat "The PickGroup preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-PickGroup (vla-get-Selection preferences) originalValue)
(alert (strcat "The PickGroup preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-11-14 14:23
