Path 属性 (ActiveX)
获取块、文档、应用程序或外部引用的路径。 支持的平台:仅限 Windows 签名VBA: object.Path
属性值只读:是的;除了 、 和 对象ComparedReferenceExternalReferenceBlock 类型:字符串 应用程序、文档或引用的路径。 言论没有其他评论。 例子VBA: Sub Example_Path()
' This example returns the path of the drawing and application.
' If the drawing has not been saved, the path of the
' document will be blank.
Dim docPath As String
docPath = ThisDrawing.Path
MsgBox "The Path of the current drawing is " & docPath, , "Path Example"
Dim appPath As String
appPath = ThisDrawing.Application.Path
MsgBox "The Path of the current appication is " & appPath, , "Path Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Path()
;; This example returns the path of the drawing and application.
;; If the drawing has not been saved, the path of the
;; document will be blank.
(setq docPath (vla-get-Path doc))
(alert (strcat "The Path of the current drawing is " docPath))
(setq appPath (vla-get-Path acadObj))
(alert (strcat "The Path of the current appication is " appPath))
GMT+8, 2026-11-12 12:36
