PageSetupOverridesTemplateFile 属性 (ActiveX)
指定页面设置替代的默认模板。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 包含页面设置覆盖的默认图形样板文件。 言论没有其他评论。 例子VBA: Sub Example_PageSetupOverridesTemplateFile()
' Note: Change the file path and name to a valid file on your system.
Dim MyFiles As AcadPreferencesFiles
Set MyFiles = AcadApplication.Preferences.Files
MyFiles.PageSetupOverridesTemplateFile = "C:\MyTemplate.dwt"
可视化 LISP: (vl-load-com)
(defun c:Example_PageSetupOverridesTemplateFile()
; Note: Change the file path and name to a valid file on your system.
(setq MyFiles (vla-get-Files preferences))
(vla-put-PageSetupOverridesTemplateFile MyFiles "C:\\MyTemplate.dwt")
GMT+8, 2026-11-12 12:22
