MinorAxis 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 817| 评论: 0|原作者: admin|来自: AutoCAD
指定椭圆的短轴方向。
object.MinorAxis
类型:椭圆
此属性应用于的对象。
只读:是的
类型:变体(双打的三元素阵列)
定义短轴的 3D 向量。向量起源于椭圆中心。
椭圆的长轴称为长轴;较短的是短轴。
Sub Example_MinorAxis()
    ' This example creates an ellipse and returns the minor
    ' axis for that ellipse.
    Dim ellObj As AcadEllipse
    Dim majAxis(0 To 2) As Double
    Dim center(0 To 2) As Double
    Dim radRatio As Double
    ' Create an ellipse in model space
    center(0) = 5#: center(1) = 5#: center(2) = 0#
    majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
    radRatio = 0.3
    Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
    ZoomAll
    ' Find the minor axis for the ellipse
    Dim minorAxis As Variant
    minorAxis = ellObj.minorAxis
    MsgBox "The ellipse has a minor axis of " & minorAxis(0) & ", " & minorAxis(1) & ", " & minorAxis(2), vbInformation, "MinorAxis Example"
(defun c:Example_MinorAxis()
    ;; This example creates an ellipse and returns the minor
    ;; axis for that ellipse.
    ;; Create an ellipse in model space
    (setq center (vlax-3d-point 5 5 0)
          majAxis (vlax-3d-point 10 20 0)
          radRatio 0.3)
    (setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio))
    (vla-ZoomAll acadObj)
    ;; Find the minor axis for the ellipse
    (setq minorAxis (vlax-variant-value (vla-get-MinorAxis ellObj)))
    (alert (strcat "The ellipse has a minor axis of " (rtos (vlax-safearray-get-element minorAxis 0) 2) ", "
                                                      (rtos (vlax-safearray-get-element minorAxis 1) 2) ", "
                                                      (rtos (vlax-safearray-get-element minorAxis 2) 2)))
GMT+8, 2026-11-12 12:37
