MaxAutoCADWindow 属性 (ActiveX)
指定启动时 AutoCAD 窗口是否应填充整个屏幕区域。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_MaxAutoCADWindow()
' MaxAutoCADWindow. It then changes the value, and finally
Dim currMaxAutoCADWindow As Boolean
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current MaxAutoCADWindow value
currMaxAutoCADWindow = preferences.DISPLAY.MaxAutoCADWindow
MsgBox "The current value for MaxAutoCADWindow is " & preferences.DISPLAY.MaxAutoCADWindow, vbInformation, "MaxAutoCADWindow Example"
' Change the value for MaxAutoCADWindow
preferences.DISPLAY.MaxAutoCADWindow = Not (currMaxAutoCADWindow)
MsgBox "The new value for MaxAutoCADWindow is " & preferences.DISPLAY.MaxAutoCADWindow, vbInformation, "MaxAutoCADWindow Example"
' Reset MaxAutoCADWindow to its original value
preferences.DISPLAY.MaxAutoCADWindow = currMaxAutoCADWindow
MsgBox "The MaxAutoCADWindow value is reset to " & preferences.DISPLAY.MaxAutoCADWindow, vbInformation, "MaxAutoCADWindow Example"
可视化 LISP: (vl-load-com)
(defun c:Example_MaxAutoCADWindow()
;; MaxAutoCADWindow. It then changes the value, and finally
;; Retrieve the current MaxAutoCADWindow value
(setq currMaxAutoCADWindow (vla-get-MaxAutoCADWindow (vla-get-Display preferences)))
(alert (strcat "The current value for MaxAutoCADWindow is " (if (= currMaxAutoCADWindow :vlax-true) "True" "False")))
;; Change the value for MaxAutoCADWindow
(vla-put-MaxAutoCADWindow (vla-get-Display preferences) (if (= currMaxAutoCADWindow :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The new value for MaxAutoCADWindow is " (if (= (vla-get-MaxAutoCADWindow (vla-get-Display preferences)) :vlax-true) "True" "False")))
;; Reset MaxAutoCADWindow to its original value
(vla-put-MaxAutoCADWindow (vla-get-Display preferences) currMaxAutoCADWindow)
(alert (strcat "The MaxAutoCADWindow value is reset to " (if (= (vla-get-MaxAutoCADWindow (vla-get-Display preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-11-12 12:48
