MainDictionary 属性 (ActiveX)
指定用于拼写检查的当前词典。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 要使用的拼写检查词典。 言论没有其他评论。 例子VBA: Sub Example_MainDictionary()
' MainDictionary. It then changes the value, and finally
Dim currMainDictionary As String
Dim newMainDictionary As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current MainDictionary value
currMainDictionary = preferences.Files.MainDictionary
MsgBox "The current value for MainDictionary is " & currMainDictionary, vbInformation, "MainDictionary Example"
' Change the value for MainDictionary
newMainDictionary = "TestMainDictionary"
preferences.Files.MainDictionary = newMainDictionary
MsgBox "The new value for MainDictionary is " & newMainDictionary, vbInformation, "MainDictionary Example"
' Reset MainDictionary to its original value
preferences.Files.MainDictionary = currMainDictionary
MsgBox "The MainDictionary value is reset to " & currMainDictionary, vbInformation, "MainDictionary Example"
可视化 LISP: (vl-load-com)
(defun c:Example_MainDictionary()
;; MainDictionary. It then changes the value, and finally
;; Retrieve the current MainDictionary value
(setq currMainDictionary (vla-get-MainDictionary (vla-get-Files preferences)))
(alert (strcat "The current value for MainDictionary is " currMainDictionary))
;; Change the value for MainDictionary
(setq newMainDictionary "TestMainDictionary")
(vla-put-MainDictionary (vla-get-Files preferences) newMainDictionary)
(alert (strcat "The new value for MainDictionary is " newMainDictionary))
;; Reset MainDictionary to its original value
(vla-put-MainDictionary (vla-get-Files preferences) currMainDictionary)
(alert (strcat "The MainDictionary value is reset to " currMainDictionary))
GMT+8, 2026-11-13 13:36
