Linetypes 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 602| 评论: 0|原作者: admin|来自: AutoCAD
获取文档的 Linetypes 集合。
object.Linetypes
类型:数据库、文档
此属性应用于的对象。
只读:是的
类型:线型
文档的集合。Linetypes
Sub Example_Linetypes()
    ' This example finds the linetypes collection and
    ' lists all the available linetypes in the collection.
    Dim linetypeColl As AcadLineTypes
    Dim entry As AcadLineType
    Dim msg As String
    ' Return the linetype collection object of the active document
    Set linetypeColl = ThisDrawing.Linetypes
    ' List all available linetypes
    For Each entry In linetypeColl
        msg = msg & entry.name & vbCrLf
    Next
    MsgBox "The linetypes available in this drawing are:" & vbCrLf & msg, vbInformation, "Linetypes Example"
(defun c:Example_Linetypes()
    ;; This example finds the linetypes collection and
    ;; lists all the available linetypes in the collection.
    ;; Return the linetype collection object of the active document
    (setq linetypeColl (vla-get-Linetypes doc))
    ;; List all available linetypes
    (setq msg "")
    (vlax-for entry linetypeColl
        (setq msg (strcat msg (vla-get-Name entry) "\n"))
    (alert (strcat "The linetypes available in this drawing are:\n" msg))
GMT+8, 2026-11-14 18:20
