Linetype 属性 (ActiveX)
指定对象的线型。 支持的平台:仅限 Windows 签名VBA: object.Linetype 属性值只读:不;只写对象除外Group 类型:字符串 对象的线型。默认线型为图层的线型 (ByLayer)。
言论线型值标识用于绘制线条的一系列点和破折号。如果未指定线型,则当前活动线型将用于新图元。如果为实体指定了线型,则忽略当前活动线型。使用该属性可以设置或查询当前活动线型。ActiveLinetype 注意:无法以编程方式创建线型。可以通过使用 Load 方法首先加载线型,然后使用 Add 方法将其添加到集合中,将现有线型添加到图形中。Linetypes
例子VBA: Sub Example_Linetype()
' This example searches for the linetype DashDot. If it is
' not found, it is added from the acad.lin file. Then a
' line is created and changed to the DashDot linetype.
' Search the linetypes collection for the DashDot linetype.
Dim entry As AcadLineType
Dim found As Boolean
found = False
For Each entry In ThisDrawing.Linetypes
If StrComp(entry.name, "DASHDOT", 1) = 0 Then
found = True
Exit For
End If
Next
If Not (found) Then ThisDrawing.Linetypes.Load "DASHDOT", "acad.lin"
' Create the line
Dim lineObj As AcadLine
startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0#
endPoint(0) = 4#: endPoint(1) = 4#: endPoint(2) = 0#
' Change the linetype of the line
lineObj.Linetype = "DASHDOT"
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_Linetype()
;; This example searches for the linetype DashDot. If it is
;; not found, it is added from the acad.lin file. Then a
;; line is created and changed to the DashDot linetype.
;; Search the linetypes collection for the DashDot linetype.
(setq found :vlax-false)
(vlax-for entry (vla-get-Linetypes doc)
(if (= (vla-get-Name entry) "DASHDOT")
(setq found :vlax-true)
(if (= found :vlax-false)
(vla-Load (vla-get-Linetypes doc) "DASHDOT" "acad.lin")
;; Create the line
(setq startPoint (vlax-3d-point 1 1 0)
endPoint (vlax-3d-point 4 4 0))
;; Change the linetype of the line
(vla-put-Linetype lineObj "DASHDOT")
(vla-ZoomAll acadObj)
GMT+8, 2026-11-13 13:45
