Limits 属性 (ActiveX)
指定绘图限制。 支持的平台:仅限 Windows 属性值只读:不 类型:变体(双打数组) 包含四个值的数组。第一对值定义左下限的 X 和 Y 坐标,第二对值定义右上限的 X 和 Y 坐标。 言论绘图极限是世界坐标系 (WCS) 中的二维点,分别表示左下角和右上角的极限。不能对 Z 方向施加限制。 绘图限制还控制可见栅格覆盖的绘图部分,并确定方法显示的最小区域。ZoomAll 注意:左下限控制 LIMMIN 系统变量。右上限控制 LIMMAX 系统变量。LIMCHECK 系统变量打开和关闭当前空间的限制检查。
例子VBA: Sub Example_Limits()
' This example finds the current limits for the drawing.
' It then changes the limits for the drawing. The grid
' is turned on to show the limits.
' Turn on the grid for the active viewport
ThisDrawing.ActiveViewport.GridOn = True
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
' Find the current limits
Dim currLimits As Variant
currLimits = ThisDrawing.Limits
MsgBox "The current drawing limits are " & vbCrLf _
& "Lower-left corner " & ThisDrawing.Limits(0) & ", " & ThisDrawing.Limits(1) & vbCrLf _
& "Upper-right corner " & ThisDrawing.Limits(2) & ", " & ThisDrawing.Limits(3), , "Limits Example"
' Change the limits
Dim newLimits(0 To 3) As Double
newLimits(0) = 2#: newLimits(1) = 2#: newLimits(2) = 4#: newLimits(3) = 4#
ThisDrawing.Limits = newLimits
ThisDrawing.Regen acActiveViewport
MsgBox "The new drawing limits are " & vbCrLf _
' Reset the drawing limits
ThisDrawing.Limits = currLimits
MsgBox "The drawing limits have been reset to " & vbCrLf _
可视化 LISP: (vl-load-com)
(defun c:Example_Limits()
;; This example finds the current limits for the drawing.
;; It then changes the limits for the drawing. The grid
;; is turned on to show the limits.
;; Turn on the grid for the active viewport
(vla-put-GridOn (vla-get-ActiveViewport doc) :vlax-true)
(vla-put-ActiveViewport doc (vla-get-ActiveViewport doc))
;; Find the current limits
(setq currLimits (vlax-variant-value (vla-get-Limits doc)))
(setq tempLimits (vlax-safearray->list currLimits))
(alert (strcat "The current drawing limits are"
"\nLower-left corner " (rtos (nth 0 tempLimits) 2) ", " (rtos (nth 1 tempLimits) 2)
"\nUpper-right corner " (rtos (nth 2 tempLimits) 2) ", " (rtos (nth 3 tempLimits) 2)))
;; Change the limits
(setq newLimits (vlax-make-safearray vlax-vbDouble '(0 . 3)))
(vlax-safearray-fill newLimits '(2 2 4 4))
(vla-put-Limits doc newLimits)
(vla-Regen doc acActiveViewport)
(setq tempLimits (vlax-safearray->list newLimits))
(alert (strcat "The new drawing limits are"
;; Reset the drawing limits
(vla-put-Limits doc currLimits)
(alert (strcat "The drawing limits have been reset to"
GMT+8, 2026-11-14 14:23
