Length 属性 (ActiveX)
2024-5-18 18:22| 发布者: admin| 查看: 659| 评论: 0|原作者: admin|来自: AutoCAD
Length 属性 (ActiveX)
获取对象的长度。
object.Length
类型:3DPolyline、Line、LWPolyline、PointCloud、折线、SweptSurface
此属性应用于的对象。
只读:是的
类型:双
线的长度。
Sub Example_Length()
   ' This example adds a line in model space and returns the length of the new line
    Dim lineObj As AcadLine
    Dim startPoint(0 To 2) As Double, endPoint(0 To 2)  As Double
    ' Define the start and end points for the line
    startPoint(0) = 1: startPoint(1) = 1: startPoint(2) = 0
    endPoint(0) = 5: endPoint(1) = 5: endPoint(2) = 0
    ' Create the line in model space
    MsgBox "The length of the new Line is: " & lineObj.length
(defun c:Example_Length()
    ;; This example adds a line in model space and returns the length of the new line
    ;; Define the start and end points for the line
    (setq startPoint (vlax-3d-point 1 1 0)
          endPoint (vlax-3d-point 5 5 0))
    ;; Create the line in model space
    (vla-ZoomAll acadObj)
    (alert (strcat "The length of the new Line is: " (rtos (vla-get-Length lineObj) 2)))
GMT+8, 2026-11-13 13:47
