LayoutCrosshairColor 属性 (ActiveX)
指定图纸空间布局的十字准线和文本的颜色。 支持的平台:仅限 Windows 属性值只读:不 类型:OLE_COLOR(常量)
言论此属性的初始值是 Windows 标准文本颜色。 若要指定模型空间布局的十字线颜色,请使用该属性。ModelCrosshairColor 例子VBA: Sub Example_LayoutCrosshairColor()
' This example reads and modifies the preference value that controls
' the color of the crosshairs and text for paper space layouts.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesDisplay
' Get the display preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Display
' Switch to paper space to view this change
ThisDrawing.ActiveSpace = acPaperSpace
originalValue = ACADPref.LayoutCrosshairColor
MsgBox "The LayoutCrosshairColor preference is: " & originalValue
' Modify the LayoutCrosshairColor preference by making it red
ACADPref.LayoutCrosshairColor = vbRed
newValue = ACADPref.LayoutCrosshairColor
MsgBox "The LayoutCrosshairColor preference has been set to: " & newValue
' this preference in effect
ACADPref.LayoutCrosshairColor = originalValue
MsgBox "The LayoutCrosshairColor preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_LayoutCrosshairColor()
;; This example reads and modifies the preference value that controls
;; the color of the crosshairs and text for paper space layouts.
;; When finished, this example resets the preference value back to
;; its original value.
;; Switch to paper space to view this change
(vla-put-ActiveSpace doc acPaperSpace)
(setq originalValue (vlax-variant-change-type (vla-get-LayoutCrosshairColor (vla-get-Display preferences)) vlax-vbLong))
(alert (strcat "The LayoutCrosshairColor preference is: " (itoa (vlax-variant-value originalValue))))
;; Modify the LayoutCrosshairColor preference by making it red
(vla-put-LayoutCrosshairColor (vla-get-Display preferences) (vlax-make-variant acRed 19))
(setq newValue (vlax-variant-change-type (vla-get-LayoutCrosshairColor (vla-get-Display preferences)) vlax-vbLong))
(alert (strcat "The LayoutCrosshairColor preference has been set to: " (itoa (vlax-variant-value newValue))))
;; this preference in effect
(vla-put-LayoutCrosshairColor (vla-get-Display preferences) (vlax-variant-change-type originalValue 19))
(alert (strcat "The LayoutCrosshairColor preference was reset back to: " (itoa (vlax-variant-value originalValue))))
GMT+8, 2026-11-12 12:26
