Knots 属性 (ActiveX)
2024-5-18 18:21| 发布者: admin| 查看: 884| 评论: 0|原作者: admin|来自: AutoCAD
Knots 属性 (ActiveX)
获取样条曲线的结向量。
object.Knots
类型:样条曲线
此属性应用于的对象。
只读:不
类型:变体(双打的三元素阵列)
样条曲线的结向量。
Sub Example_Knots()
    ' This example creates a Spline object in model space and
    ' returns the knot vector for the new Spline
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double, endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    Dim knotVector As Variant
    ' Define the Spline object
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 0: fitPoints(1) = 0: fitPoints(2) = 0: fitPoints(3) = 5
    fitPoints(4) = 5: fitPoints(5) = 0: fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    ' Create new Spline object
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ' Display the knot vector of the new Spline
    knotVector = splineObj.Knots
    MsgBox "The knot vector of the new Spline is: " & vbCrLf & _
           knotVector(0) & vbCrLf & _
           knotVector(1) & vbCrLf & _
           knotVector(2)
(defun c:Example_Knots()
    ;; This example creates a Spline object in model space and
    ;; returns the knot vector for the new Spline
    ;; Define the Spline object
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(0 0 0
				     5 5 0
				     10 0 0
    ;; Create new Spline object
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
    ;; Display the knot vector of the new Spline
    (setq knotVector (vlax-safearray->list (vlax-variant-value (vla-get-Knots splineObj))))
    (alert (strcat "The knot vector of the new Spline is: "
                   "\n" (rtos (nth 0 knotVector) 2)
                   "\n" (rtos (nth 1 knotVector) 2)
                   "\n" (rtos (nth 2 knotVector) 2)))
GMT+8, 2026-11-12 12:24
