Key 属性 (ActiveX)
2024-5-18 18:21| 发布者: admin| 查看: 756| 评论: 0|原作者: admin|来自: AutoCAD
Key 属性 (ActiveX)
CopyObjects 操作中源对象的 ObjectId。
object.Key
类型: IDPair
此属性应用于的对象。
只读:是的
类型:Long_PTR
源对象的对象 ID。
使用该属性获取新创建的克隆对象的对象 ID。Value
Sub Example_Key()
    ' This example creates two Circle objects and uses the CopyObjects
    ' method to copy them. It then returns the
    ' object IDs of the source objects using the Key property and uses these
    ' values to remove the original (source) objects
    Dim circleObj1 As AcadCircle, circleObj2 As AcadCircle
    Dim circleObj1Copy As AcadCircle, circleObj2Copy As AcadCircle
    Dim radius1 As Double, radius2 As Double
    Dim radius1Copy As Double, radius2Copy As Double
    Dim objCollection(0 To 1) As Object
    Dim retObjects As Variant
    Dim IDPairs As Variant
    Dim SourceObject As AcadObject
    ' Define the Circle object
    centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
    radius1 = 5#: radius2 = 7#
    radius1Copy = 1#: radius2Copy = 2#
    ' Add two circles to the drawing
    Set circleObj1 = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius1)
    Set circleObj2 = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius2)
    ' Copy objects
    ' First put the objects to be copied into a form compatible with CopyObjects
    Set objCollection(0) = circleObj1
    Set objCollection(1) = circleObj2
    ' Copy object and get back a collection of the new objects (copies)
    retObjects = ThisDrawing.CopyObjects(objCollection, , IDPairs)
    ' Get newly created object and apply new properties to the copies
    Set circleObj1Copy = retObjects(0)
    Set circleObj2Copy = retObjects(1)
    circleObj1Copy.radius = radius1Copy
    circleObj2Copy.radius = radius2Copy
    ' Display the object IDs of the source objects used for the copy
    MsgBox "The first source object ID is: " & IDPairs(0).key & vbCrLf & _
           "The second source object ID is: " & IDPairs(1).key
    ' This key can be used with objectIDtoObject to reference the source objects,
    ' which is handy if the user manually selected the source objects.
    ' Delete the source objects from the ID obtained
    Set SourceObject = ThisDrawing.ObjectIdToObject(IDPairs(0).key)
    SourceObject.Delete
    Set SourceObject = ThisDrawing.ObjectIdToObject(IDPairs(1).key)
    SourceObject.Delete
    MsgBox "The source objects have just been deleted!", vbInformation
(defun c:Example_Key()
    ;; This example creates two Circle objects and uses the CopyObjects
    ;; method to copy them. It then returns the
    ;; object IDs of the source objects using the Key property and uses these
    ;; values to remove the original (source) objects
    ;; Define the Circle object
    (setq centerPoint (vlax-3d-point 0 0 0)
          radius1 5
          radius2 7
          radius1Copy 1
          radius2Copy 2)
    ;; Add two circles to the drawing
    (setq circleObj1 (vla-AddCircle modelSpace centerPoint radius1))
    (setq circleObj2 (vla-AddCircle modelSpace centerPoint radius2))
    (vla-ZoomAll acadObj)
    ;; Copy objects
    ;; First put the objects to be copied into a form compatible with CopyObjects
    (setq objCollection (vlax-make-safearray vlax-vbObject '(0 . 1)))
    (vlax-safearray-put-element objCollection 0 circleObj1)
    (vlax-safearray-put-element objCollection 1 circleObj2)
    ;; Copy object and get back a collection of the new objects (copies)
    (setq retObjects (vlax-variant-value (vla-CopyObjects doc objCollection nil 'IDPairs)))
    ;; Get newly created object and apply new properties to the copies
    (setq circleObj1Copy (vlax-safearray-get-element retObjects 0))
    (setq circleObj2Copy (vlax-safearray-get-element retObjects 1))
    (vla-put-Radius circleObj1Copy radius1Copy)
    (vla-put-Radius circleObj2Copy radius2Copy)
    ;; Display the object IDs of the source objects used for the copy
    (alert (strcat "The first source object ID is: " (itoa (vla-get-Key (vlax-safearray-get-element IDPairs 0)))
                   "\nThe second source object ID is: " (itoa (vla-get-Key (vlax-safearray-get-element IDPairs 1)))))
    ;; This key can be used with objectIDtoObject to reference the source objects,
    ;; which is handy if the user manually selected the source objects.
    ;; Delete the source objects from the ID obtained
    (setq SourceObject (vla-ObjectIdToObject doc (vla-get-Key (vlax-safearray-get-element IDPairs 0))))
    (vla-Delete SourceObject)
    (setq SourceObject (vla-ObjectIdToObject doc (vla-get-Key (vlax-safearray-get-element IDPairs 1))))
    (alert "The source objects have just been deleted!")
GMT+8, 2026-11-20 12:41
