IsRational 属性 (ActiveX)
2024-5-18 18:21| 发布者: admin| 查看: 950| 评论: 0|原作者: admin|来自: AutoCAD
确定给定样条曲线是否为有理曲线。
object.IsRational
类型:样条曲线
此属性应用于的对象。
只读:是的
类型:布尔
  • True:样条是有理的。
  • False:样条曲线不是有理的。
Sub Example_IsRational()
    ' This example creates a spline object in model space.
    ' It then determines whether the spline is rational or non-rational
    ' based on the IsRational property.
    ' Create the spline
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double
    Dim endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
    fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
    fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ZoomAll
    ' Display a message according to the IsRational value for the spline.
    If splineObj.IsRational Then
        MsgBox "The newly created Spline is a rational Spline", , "IsRational Example"
    Else
        MsgBox "The newly created Spline is a non-rational Spline", , "IsRational Example"
    End If
(defun c:Example_IsRational()
    ;; This example creates a Spline object in model space and
    ;; determines whether the Spline is planar
    ;; Define the Spline object
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(0 0 0
				     5 5 0
				     10 0 0
    ;; Create new Spline object
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
    ;; Display a message according to the IsRational value for the spline.
    (if (= (vla-get-IsRational splineObj) :vlax-true)
        (alert "The newly created Spline is a rational Spline")
        (alert "The newly created Spline is a non-rational Spline")
GMT+8, 2026-11-14 18:19
