Invisible 属性 (ActiveX)
指定属性或属性引用是否不可见。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论不会显示或绘制不可见属性。 属性只能作为四种可选模式之一存在:常量、预设、不可见或验证。AFLAGS 系统变量存储当前模式设置。可以使用该属性查询当前模式。Mode 例子VBA: Sub Example_Invisible()
' This example creates an attribute definition in model space.
' It then queries the visibility of the attribute, changes
' the visibility, and queries the visibility again.
Dim attributeObj As AcadAttribute
Dim height As Double
Dim mode As Long
Dim prompt As String
Dim tag As String
Dim value As String
' Define the attribute definition
height = 1#
mode = acAttributeModeVerify
prompt = "New Prompt"
insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0
tag = "New_Tag"
value = "New Value"
' Create the attribute definition object in model space
Set attributeObj = ThisDrawing.ModelSpace.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
ZoomAll
' Find the current visibility for the attribute
GoSub QUERYSTATUS
' Change the visibility of the attribute
attributeObj.Invisible = Not attributeObj.Invisible
ZoomAll
GoSub QUERYSTATUS
Exit Sub
QUERYSTATUS:
If attributeObj.Invisible Then
MsgBox "The attribute is invisible."
Else
MsgBox "The attribute is visible."
End If
Return
可视化 LISP: (vl-load-com)
(defun c:Example_Invisible()
;; This example creates an attribute definition in model space.
;; It then queries the visibility of the attribute, changes
;; the visibility, and queries the visibility again.
;; Define the attribute definition
(setq insertionPoint (vlax-3d-point 5 5 0)
attHeight 1
attMode acAttributeModeVerify
attPrompt "New Prompt"
attTag "NEW_TAG"
attValue "New Value")
;; Create the attribute definition object in model space
(setq attributeObj (vla-AddAttribute modelSpace attHeight attMode attPrompt insertionPoint attTag attValue))
(vla-ZoomAll acadObj)
;; Find the current visibility for the attribute
(if (= (vla-get-Invisible attributeObj) :vlax-true)
(alert "The attribute is invisible.")
(alert "The attribute is visible.")
;; Change the visibility of the attribute
(vla-put-Invisible attributeObj (if (= (vla-get-Invisible attributeObj) :vlax-true) :vlax-false :vlax-true))
GMT+8, 2026-11-12 12:37
