InsertionPoint 属性 (ActiveX)
2024-5-18 18:21| 发布者: admin| 查看: 986| 评论: 0|原作者: admin|来自: AutoCAD
公差、文本、块或形状的插入点,以及 OLE 对象的原点(左上角)。
object.InsertionPoint
类型:属性、 AttributeReference、 BlockReference、 ComparedReference、 ExternalReference、 MInsertBlock、 MText、 OLE、 PointCloud、 PointCloudEx、 形状、 表、 文本、 容差
此属性应用于的对象。
只读:不
类型:变体(双打的三元素阵列)
表示插入点或原点的 3D WCS 坐标。
MText:指定文本边界角的位置。使用该属性指定要定位在此插入点处的文本边界的哪个角。AttachmentPoint
文本:此属性是只读的,但属性设置为 、 或 的文本除外。若要放置对齐方式不是左对齐、对齐或适合的文本,请使用该属性。AlignmentacAlignmentLeftacAlignmentAlignedacAlignmentFitTextAlignmentPoint
Sub Example_InsertionPoint()
    ' This example creates a text object in model space.
    ' It then changes the insertion point of the text object.
    Dim textObj As AcadText
    Dim textString As String
    Dim height As Double
    ' Define the text object
    textString = "Hello, World."
    insertionPoint(0) = 2: insertionPoint(1) = 2: insertionPoint(2) = 0
    height = 0.5
    ' Create the text object in model space
    Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height)
    ZoomAll
    ' Return the current value of the insertion point
    Dim currInsertionPoint As Variant
    currInsertionPoint = textObj.insertionPoint
    MsgBox "The insertion point of the text is " & currInsertionPoint(0) & ", " & currInsertionPoint(1) & ", " & currInsertionPoint(2), vbInformation, "InsertionPoint Example"
    ' Change the insertion point of the text object and
    ' update the display of the text object.
    insertionPoint(0) = 3: insertionPoint(1) = 3: insertionPoint(2) = 0
    textObj.insertionPoint = insertionPoint
    textObj.Update
    MsgBox "The new insertion point of the text is " & textObj.insertionPoint(0) & ", " & textObj.insertionPoint(1) & ", " & textObj.insertionPoint(2), vbInformation, "InsertionPoint Example"
(defun c:Example_InsertionPoint()
    ;; This example creates a text object in model space.
    ;; It then changes the insertion point of the text object.
    ;; Define the text object
    (setq textString "Hello, World."
          insertionPoint (vlax-3d-point 2 2 0)
          height 0.5)
    ;; Create the text object in model space
    (setq textObj (vla-AddText modelSpace textString insertionPoint height))
    (vla-ZoomAll acadObj)
    ;; Return the current value of the insertion point
    (setq currInsertionPoint (vlax-safearray->list (vlax-variant-value (vla-get-InsertionPoint textObj))))
    (alert (strcat "The insertion point of the text is " (rtos (nth 0 currInsertionPoint) 2) ", "
                                                         (rtos (nth 1 currInsertionPoint) 2) ", "
                                                         (rtos (nth 2 currInsertionPoint) 2)))
    ;; Change the insertion point of the text object and
    ;; update the display of the text object.
    (setq insertionPoint (vlax-3d-point 3 3 0))
    (vla-put-insertionPoint textObj insertionPoint)
    (vla-Update textObj)
    (setq newInsertionPoint (vlax-safearray->list (vlax-variant-value (vla-get-InsertionPoint textObj))))
    (alert (strcat "The new insertion point of the text is " (rtos (nth 0 newInsertionPoint) 2) ", "
                                                             (rtos (nth 1 newInsertionPoint) 2) ", "
                                                             (rtos (nth 2 newInsertionPoint) 2)))
GMT+8, 2026-11-15 19:41
