HasAttributes 属性 (ActiveX)
指定块中是否有任何属性。 支持的平台:仅限 Windows 签名VBA: object.HasAttributes
属性值只读:是的 类型:布尔
言论如果块引用包含任何可编辑或常量(不可编辑)属性,则此属性为。如果没有属性。TrueFalse 若要返回与块关联的对象数组,请使用该方法。AttributeGetAttributes 例子VBA: Sub Example_HasAttributes()
' This example first creates a block without attributes.
' It then inserts the block and checks whether it has attributes.
' It then adds attributes to the block and inserts it again.
' Then it checks the new block reference for attributes.
' Create the block
Dim blockObj As AcadBlock
Dim insertionPnt(0 To 2) As Double
insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "CircleBlock")
' Add a circle to the block
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 0: center(1) = 0: center(2) = 0
radius = 1
Set circleObj = blockObj.AddCircle(center, radius)
' Insert the block
Dim blockRefObj As AcadBlockReference
insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "CircleBlock", 1#, 1#, 1#, 0)
MsgBox "This block reference " & IIf(blockRefObj.HasAttributes, "has attributes.", "does not have attributes."), , "Has Attributes Example"
' Add attributes to the block definition.
' Define the attribute definition.
Dim attributeObj As AcadAttribute
Dim height As Double
Dim mode As Long
Dim prompt As String
Dim tag As String
Dim value As String
height = 1#
mode = acAttributeModeVerify
prompt = "Attribute Prompt"
insertionPoint(0) = 1#: insertionPoint(1) = 1#: insertionPoint(2) = 0
tag = "Attribute_Tag"
value = "Attribute Value"
' Create the attribute definition
Set attributeObj = blockObj.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
' Insert the block again
Dim blockRefObj2 As AcadBlockReference
insertionPnt(0) = 3#: insertionPnt(1) = 3#: insertionPnt(2) = 0
Set blockRefObj2 = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "CircleBlock", 1#, 1#, 1#, 0)
ZoomAll
MsgBox "The first block reference " & IIf(blockRefObj.HasAttributes, "has attributes.", "does not have attributes.") & vbCrLf & _
"The second block reference " & IIf(blockRefObj2.HasAttributes, "has attributes.", "does not have attributes."), , "Has Attributes Example"
可视化 LISP: (vl-load-com)
(defun c:Example_HasAttributes()
;; This example first creates a block without attributes.
;; It then inserts the block and checks whether it has attributes.
;; It then adds attributes to the block and inserts it again.
;; Then it checks the new block reference for attributes.
;; Create the block
(setq insertionPnt (vlax-3d-point 0 0 0))
(setq blockObj (vla-Add (vla-get-Blocks doc) insertionPnt "CircleBlock"))
;; Add a circle to the block
(setq center (vlax-3d-point 0 0 0))
(setq radius 1)
(setq circleObj (vla-AddCircle blockObj center radius))
;; Insert the block
(setq insertionPnt (vlax-3d-point 2 2 0))
(setq blockRefObj (vla-InsertBlock modelSpace insertionPnt "CircleBlock" 1 1 1 0))
(vla-ZoomAll acadObj)
(alert (strcat "This block reference " (if (= (vla-get-HasAttributes blockRefObj) :vlax-true) "has attributes." "does not have attributes.")))
;; Add attributes to the block definition.
;; Define the attribute definition.
(setq insertionPoint (vlax-3d-point 1 1 0)
attHeight 1
attMode acAttributeModeVerify
attPrompt "Attribute Prompt"
attTag "Attribute_Tag"
attValue "Attribute Value")
;; Create the attribute definition
(setq attributeObj (vla-AddAttribute blockObj attHeight attMode attPrompt insertionPoint attTag attValue))
;; Insert the block again
(setq insertionPnt (vlax-3d-point 3 3 0))
(setq blockRefObj2 (vla-InsertBlock modelSpace insertionPnt "CircleBlock" 1 1 1 0))
(alert (strcat "The first block reference " (if (= (vla-get-HasAttributes blockRefObj) :vlax-true) "has attributes." "does not have attributes.")
"\nThe second block reference " (if (= (vla-get-HasAttributes blockRefObj2) :vlax-true) "has attributes." "does not have attributes.")))
GMT+8, 2026-11-15 15:19
