Handle 属性 (ActiveX)
获取对象的句柄。 支持的平台:仅限 Windows 签名VBA: object.Handle 属性值只读:是的 类型:字符串 实体的句柄。 言论对象 ID 和唯一句柄是引用对象的两种方式。在对象的生存期内,手柄在图形中是永久性的(保持不变)。 通常,除非您计划使用需要对象 ID 的某些 ObjectARX 函数,否则请使用句柄。 例子VBA: Sub Example_Handle()
' This example creates several objects in model space.
' It then iterates through the objects in model space and displays the
' Handle for each object found.
' Create a Ray object in model space
Dim rayObj As AcadRay
Dim basePoint(0 To 2) As Double
Dim SecondPoint(0 To 2) As Double
basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0#
SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0#
Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, SecondPoint)
' Create a polyline object in model space
Dim points(0 To 5) As Double
points(0) = 3: points(1) = 7
points(2) = 9: points(3) = 2
points(4) = 3: points(5) = 5
Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
plineObj.Closed = True
' Create a line object in model space
Dim lineObj As AcadLine
startPoint(0) = 0: startPoint(1) = 0: startPoint(2) = 0
endPoint(0) = 2: endPoint(1) = 2: endPoint(2) = 0
' Create a circle object in model space
Dim circObj As AcadCircle
Dim centerPt(0 To 2) As Double
Dim radius As Double
centerPt(0) = 5: centerPt(1) = 3: centerPt(2) = 0
radius = 3
Set circObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius)
' Create an ellipse object in model space
Dim ellObj As AcadEllipse
Dim majAxis(0 To 2) As Double
Dim center(0 To 2) As Double
Dim radRatio As Double
center(0) = 5#: center(1) = 5#: center(2) = 0#
majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
radRatio = 0.3
Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
ZoomAll
' Iterate through the model space collection and display
' the handle of each object found.
Dim entHandle As String
Dim entry As AcadEntity
For Each entry In ThisDrawing.ModelSpace
entHandle = entry.handle
entry.Highlight (True)
MsgBox "The handle of this object is " & entHandle, vbInformation, "Handle Example"
entry.Highlight (False)
Next
可视化 LISP: (vl-load-com)
(defun c:Example_Handle()
;; This example creates several objects in model space.
;; It then iterates through the objects in model space and displays the
;; Handle for each object found.
;; Create a Ray object in model space
(setq basePoint (vlax-3d-point 3 3 0)
secondPoint (vlax-3d-point 1 3 0))
(setq rayObj (vla-AddRay modelSpace basePoint SecondPoint))
;; Create a polyline object in model space
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 5)))
(vlax-safearray-fill points '(3 7
9 2
3 5
(setq plineObj (vla-AddLightWeightPolyline modelSpace points))
(vla-put-Closed plineObj :vlax-true)
;; Create a line object in model space
(setq startPoint (vlax-3d-point 0 0 0)
endPoint (vlax-3d-point 2 2 0))
;; Create a circle object in model space
(setq centerPt (vlax-3d-point 20 30 0)
radius 3)
(setq circObj (vla-AddCircle modelSpace centerPt radius))
;; Create an ellipse object in model space
(setq center (vlax-3d-point 5 5 0)
majAxis (vlax-3d-point 10 20 0)
radRatio 0.3)
(setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio))
(vla-ZoomAll acadObj)
;; Iterate through the model space collection and display
;; the handle of each object found.
(vlax-for entry (vla-get-ModelSpace doc)
(setq entHandle (vla-get-Handle entry))
(vla-Highlight entry :vlax-true)
(alert (strcat "The handle of this object is " entHandle))
(vla-Highlight entry :vlax-false)
GMT+8, 2026-11-13 13:45
