ExtLine1Point 属性 (ActiveX)
指定延长线 1 的原点。 支持的平台:仅限 Windows 属性值只读:不 类型:变体(双打的三元素阵列) 表示第一条延伸线原点的 3D 坐标。 言论对齐尺寸的尺寸线将平行于连接延伸线 1 和 2 原点的线。 ![]() 要标注尺寸的线 ![]() 创建的维度 例子VBA: Sub Example_ExtLine1Point()
' This example creates an aligned dimension and then changes the
' ExtLine1Point property for that dimension.
Dim dimObj As AcadDimAligned
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
' Define the dimension
point1(0) = 5#: point1(1) = 5#: point1(2) = 0#
point2(0) = 10#: point2(1) = 5#: point2(2) = 0#
location(0) = 5#: location(1) = 7#: location(2) = 0#
ZoomAll
MsgBox "The current value for ExtLine1Point is " & dimObj.ExtLine1Point(0) & ", " & dimObj.ExtLine1Point(1) & ", " & dimObj.ExtLine1Point(2), vbInformation, "ExtLine1Point Example"
' Change the endpoint of the first extension line
point1(0) = 2: point1(1) = 5: point1(2) = 0
dimObj.ExtLine1Point = point1
dimObj.Update
' Return the endpoint of the first extension line
' Note that the return value is a Variant
Dim retPnt As Variant
retPnt = dimObj.ExtLine1Point
MsgBox "The new value for ExtLine1Point is " & dimObj.ExtLine1Point(0) & ", " & dimObj.ExtLine1Point(1) & ", " & dimObj.ExtLine1Point(2), vbInformation, "ExtLine1Point Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ExtLine1Point()
;; This example creates an aligned dimension and then changes the
;; ExtLine1Point property for that dimension.
;; Define the dimension
point2 (vlax-3d-point 10 5 0)
(vla-ZoomAll acadObj)
(setq extLinePoint (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine1Point dimObj))))
(alert (strcat "The current value for ExtLine1Point is " (rtos (nth 0 extLinePoint) 2) ", "
(rtos (nth 1 extLinePoint) 2) ", "
(rtos (nth 2 extLinePoint) 2)))
;; Change the endpoint of the first extension line
(setq point1 (vlax-3d-point 2 5 0))
(vla-put-ExtLine1Point dimObj point1)
(vla-Update dimObj)
;; Return the endpoint of the first extension line
;; Note that the return value is a Variant
(setq retPnt (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine1Point dimObj))))
(alert (strcat "The new value for ExtLine1Point is " (rtos (nth 0 retPnt) 2) ", "
(rtos (nth 1 retPnt) 2) ", "
(rtos (nth 2 retPnt) 2)))
GMT+8, 2026-11-13 13:49
