Document 属性 (ActiveX)
2024-5-18 18:21| 发布者: admin| 查看: 607| 评论: 0|原作者: admin|来自: AutoCAD
获取对象所属的文档(绘图)。
只读:是的
类别: 文档
包含对象的文档(绘图)。
Sub Example_Document()
    ' This example creates a circle in model space and then
    ' finds the name of the document that the circle resides in.
    Dim circleObj As AcadCircle
    Dim radius As Double
    ' Define the circle
    centerPoint(0) = 0#: centerPoint(1) = 0#: centerPoint(2) = 0#
    radius = 5#
    ' Create the Circle object in model space
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
    ZoomAll
    ' Find the document name for the circle
    Dim currDoc As AcadDocument
    Set currDoc = circleObj.Document
    MsgBox "The circle resides in: " & currDoc.name
(defun c:Example_Document()
    ;; This example creates a circle in model space and then
    ;; finds the name of the document that the circle resides in.
    ;; Define the circle
    (setq centerPoint (vlax-3d-point 0 0 0)
          radius 5)
    ;; Create the Circle object in model space
    (setq circleObj (vla-AddCircle modelSpace centerPoint radius))
    (vla-ZoomAll acadObj)
    ;; Find the document name for the circle
    (setq currDoc (vla-get-Document circleObj))
    (alert (strcat "The circle resides in: " (vla-get-Name currDoc)))
GMT+8, 2026-11-12 12:39
