Display 属性 (ActiveX)
2024-5-18 18:21| 发布者: admin| 查看: 748| 评论: 0|原作者: admin|来自: AutoCAD
获取 PreferencesDisplay 对象。
object.Display
类型:首选项
此属性应用于的对象。
只读:是的
类型:首选项显示
获取对象。PreferencesDisplay
该对象保存存储在注册表中的“选项”对话框的“显示”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesDisplayDatabasePreferences
Sub Example_Display()
    ' This example obtains a reference to the Display Preferences object
    ' from the Application Preferences object, and reads one of the Display
    ' preferences
    Dim ACADPref As AcadPreferencesDisplay
    ' Obtain a reference to the Display Preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Display
    MsgBox "We now have access to the properties and methods of the Display Preferences object!"
    MsgBox "The Display preference CursorSize is set to: " & ACADPref.CursorSize
(defun c:Example_Display()
    ;; This example obtains a reference to the Display Preferences object
    ;; from the Application Preferences object, and reads one of the Display
    ;; preferences
    ;; Obtain a reference to the Display Preferences object
    (setq ACADPref (vla-get-Display preferences))
    (alert "We now have access to the properties and methods of the Display Preferences object!")
    (alert (strcat "The Display preference CursorSize is set to: " (itoa (vla-get-CursorSize ACADPref))))
GMT+8, 2026-11-12 12:39
