DimStyles 属性 (ActiveX)
获取文档的 DimStyles 集合。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_DimStyles()
' This example adds a new dimension style.
Dim dimStyle As AcadDimStyle
Set dimStyle = ThisDrawing.DimStyles.Add("TEST")
MsgBox "A new dimension style called " & dimStyle.name & " has been added to the Dimstyles collection.", vbInformation, "Dimstyles Example"
可视化 LISP: (vl-load-com)
(defun c:Example_DimStyles()
;; This example adds a new dimension style.
(setq dimStyle (vla-Add (vla-get-DimStyles doc) "TEST"))
(alert (strcat "A new dimension style called " (vla-get-Name dimStyle) " has been added to the Dimstyles collection."))
GMT+8, 2026-11-12 12:26
