DimensionLineExtend 属性 (ActiveX)
2024-5-18 18:21| 发布者: admin| 查看: 902| 评论: 0|原作者: admin|来自: AutoCAD
指定绘制倾斜描边而不是箭头时尺寸线延伸到延伸线之外的距离。
object.DimensionLineExtend
类型:DimAligned、DimArcLength、DimRotated
此属性应用于的对象。
只读:不
类型:双
一个正实数,指定将尺寸线延伸到延伸线之外的距离。
此属性的初始值为 0.0000。
注意:此属性将覆盖给定维度的 DIMDLE 系统变量的值。
Sub Example_DimensionLineExtend()
   ' uses DimensionLineExtend to specify the distance the dimension
   ' line extends beyond the extension line when oblique strokes are
   ' drawn instead of arrowheads
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 10.123: point2(1) = 5: point2(2) = 0
    dimObj.Arrowhead1Type = acArrowOblique
    dimObj.Arrowhead2Type = acArrowOblique
    MsgBox "A new Dimension has been created.  Press any key to extend the dimension lines."
    ' Round the distance of the alternate dimension to 0.50 of a unit
    dimObj.DimensionLineExtend = 2
    MsgBox "The dimension lines have been extended to: " & dimObj.DimensionLineExtend
(defun c:Example_DimensionLineExtend()
    ;; uses DimensionLineExtend to specify the distance the dimension
    ;; line extends beyond the extension line when oblique strokes are
    ;; drawn instead of arrowheads
    ;; Define the dimension
          point2 (vlax-3d-point 10.123 5 0)
    (vla-put-Arrowhead1Type dimObj acArrowOblique)
    (vla-put-Arrowhead2Type dimObj acArrowOblique)
    (vla-ZoomAll acadObj)
    (alert "A new Dimension has been created.")
    ;; Round the distance of the alternate dimension to 0.50 of a unit
    (vla-put-DimensionLineExtend dimObj 2)
    (alert (strcat "The dimension lines have been extended to: " (rtos (vla-get-DimensionLineExtend dimObj) 2)))
GMT+8, 2026-11-14 14:33
