Delta 属性 (ActiveX)
获取线的增量。 支持的平台:仅限 Windows 属性值只读:是的 类型:变体(双打的三元素阵列) 表示线的 deltaX、deltaY 和 deltaZ 值的三元素数组。 言论没有其他评论。 例子VBA: Sub Example_Delta()
' This example adds a line in model space and returns the delta of the new line
Dim lineObj As AcadLine
Dim lineDelta As Variant
Dim startPoint(0 To 2) As Double, endPoint(0 To 2) As Double
' Define the start and end points for the line
startPoint(0) = 1: startPoint(1) = 1: startPoint(2) = 0
endPoint(0) = 5: endPoint(1) = 5: endPoint(2) = 0
' Create the line in model space
Set lineObj = ThisDrawing.modelSpace.AddLine(startPoint, endPoint)
' Display the delta of the new line
lineDelta = lineObj.Delta
MsgBox "The delta of the new Line is: " & vbCrLf & _
"DeltaX: " & lineDelta(0) & vbCrLf & _
"DeltaY: " & lineDelta(1) & vbCrLf & _
"DeltaZ: " & lineDelta(2)
可视化 LISP: (vl-load-com)
(defun c:Example_Delta()
;; This example adds a line in model space and returns the delta of the new line
;; Define the start and end points for the line
(setq startPoint (vlax-3d-point 1 1 0)
endPoint (vlax-3d-point 5 5 0))
;; Create the line in model space
(vla-ZoomAll acadObj)
;; Display the delta of the new line
(setq lineDelta (vlax-safearray->list (vlax-variant-value (vla-get-Delta lineObj))))
(alert (strcat "The delta of the new Line is: "
"\nDeltaX: " (rtos (nth 0 lineDelta) 2)
"\nDeltaY: " (rtos (nth 1 lineDelta) 2)
"\nDeltaZ: " (rtos (nth 2 lineDelta) 2)
GMT+8, 2026-11-14 14:24
