DefaultOutputDevice 属性 (ActiveX)
指定新布局和模型空间的默认输出设备。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 要使用的默认打印机的名称。 言论您可以指定计算机为其配置的任何打印机,以及绘图仪配置路径中的任何 PC3 文件。 如果系统上没有设备,则此属性将返回“None”。 例子VBA: Sub Example_DefaultOutputDevice()
' This example reads and modifies the preference value that controls
' the default output device for new layouts and model space.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesOutput
' Get the output preferences object
Set ACADPref = ThisDrawing.Application.preferences.Output
originalValue = ACADPref.DefaultOutputDevice
MsgBox "The DefaultOutputDevice preference is: " & originalValue
' Modify the DefaultOutputDevice preference
ACADPref.DefaultOutputDevice = "DWG to PDF.pc3"
newValue = ACADPref.DefaultOutputDevice
MsgBox "The DefaultOutputDevice preference has been set to: " & newValue
' this preference in effect
ACADPref.DefaultOutputDevice = originalValue
MsgBox "The DefaultOutputDevice preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_DefaultOutputDevice()
;; This example reads and modifies the preference value that controls
;; the default output device for new layouts and model space.
;; When finished, this example resets the preference value back to
;; its original value.
;; Get the output preferences object
(setq ACADPref (vla-get-Output preferences))
(setq originalValue (vla-get-DefaultOutputDevice ACADPref))
(alert (strcat "The DefaultOutputDevice preference is: " originalValue))
;; Modify the DefaultOutputDevice preference
(vla-put-DefaultOutputDevice ACADPref "DWG to PDF.pc3")
(setq newValue (vla-get-DefaultOutputDevice ACADPref))
(alert (strcat "The DefaultOutputDevice preference has been set to: " newValue))
;; this preference in effect
(vla-put-DefaultOutputDevice ACADPref originalValue)
(alert (strcat "The DefaultOutputDevice preference was reset back to: " originalValue))
GMT+8, 2026-11-13 13:39
