DefaultInternetURL 属性 (ActiveX)
指定默认 Internet 地址。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 默认 Internet 地址。 言论注意:此属性的值存储在 INETLOCATION 系统变量中。
例子VBA: Sub Example_DefaultInternetURL()
' DefaultInternetURL. It then changes the value, and finally
Dim currDefaultInternetURL As String
Dim newDefaultInternetURL As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current DefaultInternetURL value
currDefaultInternetURL = preferences.Files.DefaultInternetURL
MsgBox "The current value for DefaultInternetURL is " & currDefaultInternetURL, vbInformation, "DefaultInternetURL Example"
' Change the value for DefaultInternetURL
newDefaultInternetURL = "TestDefaultInternetURL"
preferences.Files.DefaultInternetURL = newDefaultInternetURL
MsgBox "The new value for DefaultInternetURL is " & newDefaultInternetURL, vbInformation, "DefaultInternetURL Example"
' Reset DefaultInternetURL to its original value
preferences.Files.DefaultInternetURL = currDefaultInternetURL
MsgBox "The DefaultInternetURL value is reset to " & currDefaultInternetURL, vbInformation, "DefaultInternetURL Example"
可视化 LISP: (vl-load-com)
(defun c:Example_DefaultInternetURL()
;; DefaultInternetURL. It then changes the value, and finally
;; Retrieve the current DefaultInternetURL value
(setq currDefaultInternetURL (vla-get-DefaultInternetURL (vla-get-Files preferences)))
(alert (strcat "The current value for DefaultInternetURL is " currDefaultInternetURL))
;; Change the value for DefaultInternetURL
(setq newDefaultInternetURL "TestDefaultInternetURL")
(vla-put-DefaultInternetURL (vla-get-Files preferences) newDefaultInternetURL)
(alert (strcat "The new value for DefaultInternetURL is " newDefaultInternetURL))
;; Reset DefaultInternetURL to its original value
(vla-put-DefaultInternetURL (vla-get-Files preferences) currDefaultInternetURL)
(alert (strcat "The DefaultInternetURL value is reset to " currDefaultInternetURL))
GMT+8, 2026-11-12 12:37
